A couple of questions I'm hoping you guys can help me out on a few things.
My car is a '97 with 168K miles.
The driver side window has started making a very slight noise when going up and down. The passenger side window slows down when going up 3/4 of the way up, it does not however make any weird noise.
My locks also don't unlock with the remote in the winter.
My steering rack & pinion was leaking previously in the winter it is not leaking anymore but I still feel as if I should replace it.
What do you guys suggest I do?
the seals in the rack will probably not leak in hot weather (but in cold, they shrink up and that allows fluid to leak out) so ... I would try to get it fixed before the winter. Kevlo did a write up on How To ... if ya search, wasn't too long ago either.
as for the windows ... I'd guess they need to be re-greased. pull the door pannel and remove the plastic liner. apply axle grease to the slide arms. could be the motor is weakening too ... but I would guess it's more a binding issue.
the locks ... work in hot weather? oddddddd ... ????
cheers, hope some of this helps!
MaximaDrvr
Aug 19, 2015 08:20 PM
yat70458
Aug 3, 2015 01:16 PM
