Can someone with a 5spd do a quick experiment for me?
Car is sitting in the garage, engine off, hood open, ebrake off and trans in 1st.
I grabbed hold of the radiator support and pushed the whole car backwards about 4" until it stopped (trans) and then pulled it firward again until it stopped.
Did this forward and back thing several times.
Describe the sound that you hear when the trans stops the car rolling each time.
For me, the sound is like 3 or 4 distinct clicks at almost the same time. Sounds like someone biting down on hard candy.
Push the car back, crunch, pull the car forward, crunch. I actually expected the trans to stop the car almost silently, ie with no play at all.
Also, is it normal to be able to grab the driveshaft and move it in and out of the hub? It won't rotate at all, but I can move it about 1/32nd inch in and out of the hub. Both sides are like that.
Push the car back, crunch, pull the car forward, crunch. I actually expected the trans to stop the car almost silently, ie with no play at all.Also, is it normal to be able to grab the driveshaft and move it in and out of the hub? It won't rotate at all, but I can move it about 1/32nd inch in and out of the hub. Both sides are like that.
mine just rolls... i got a junk yard tranny out of a 97but i think it was outside BC i live in vancouver and own a 4th gen. the guy couldn't get a LSD axle in and ordered a non LSD axle and popped right in and i was workin on my car one day with the tranny in 1st with the e-brake off and i was able to roll the car....
yea i've noticed with my old truck if i had it in gear and e brake off it would hold it on my driveway but with my maxima if its in gear and ebrake is off it will stop then go then stop then go....any ideas?????
Originally Posted by dgeesaman
Yes, a little axial play is normal since the snap ring is what holds it axially, and snap rings don't lock it perfectly into place.
MaxLvr21
Oct 17, 2015 12:11 PM
ef9
Oct 4, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
