Sponsored by:
Sponsored by: CARiD
OK i may a boo boo 9660rpms recorded
Old Aug 24, 2007 | 09:41 PM
95turbo gxe's Avatar
Well i went to the track tonight to try the car out on 9 psi. The best I can say for the it was a trap of 85mph in the 1/8 mile. Ok the last run I made was the run I stuck 3rd gear for first. Well after that happend I cut the car off because the oil light came on with check engine light too. The power steering belt flew off in the procese. Well I got the car back to the staging lanes and started looking around to see if I could see the sending unit hoping that the power steering may have flew off and broke it. But that wasnt the case. When I crank it the car has no oil pressure and their is a little noise in the timing case. Its not knocking.
So my first question is Im wondering If I replace the oil pump is the motor toast?
How many other have broke oil pumps and what was your out come?
Old Aug 24, 2007 | 10:31 PM
SR20DEN's Avatar
VQ Wizard
Around 9500+ rpms those things begin to smash valves too. So even if the oil pump gets you in the clear, you'll want to to a compression check.
Old Aug 24, 2007 | 10:41 PM
What all will I have to do to change the oil pump. I dont have my manual with me and im wondering
Old Aug 24, 2007 | 11:34 PM
95BLKMAX's Avatar
Remove
-Belts and AC compressor and its braket
-Oil pans (upper and lower)
-crank pulley
-timing covers and equipment (always the fun stuff)
-oil pump
Old Aug 25, 2007 | 12:53 AM
i30krab's Avatar
Originally Posted by 95BLKMAX
Remove
-crank pulley
-oil pump
One other important item;
Buy an oil pump for a 3.5 motor. It will drop right in and give you more oil pressure. I know because I have one in my 96 I30.
Old Aug 25, 2007 | 10:48 AM
gtr_rider's Avatar
192.168.1.1
you probably popped the oil pump..
Old Aug 25, 2007 | 10:51 AM
mtrai760's Avatar
'Trynna' is not a word
To the OP, You don't need to post the same thing all over the forums.
97_GXE
Sep 15, 2015 06:47 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Team STILLEN
Aug 10, 2015 04:29 PM
ArcticMax
Dec 24, 2000 11:12 PM
