Tips to know: Is Battery or Alternator Dead?
Steps to check if alternator is dead:
1. Start your engine (get a jump from a good running vehicle if necessary).
2. With the engine running, disconnect the battery. If the engine dies-your alternator is dead, if it continues to run, your battery is dead. The reason for this is that the battery is used only to start a vehicle and occassionally to assist in accessories (headlights, stereo, AC, etc...) during idle or traffic stop. The alternator keeps the fuel injectors and ignition system (onboard computer, etc...) going once the vehicle has started and begins to recharge the battery from the energy used to start the vehicle.
3. So if your engine still runs after disconnecting the battery, the alternator is doing its job correctly. If it dies, then the battery was the only thing supplying the ignition system and everything else.
4. Please know that 90% of alternators die due to a failing battery.
5. So if it proves to be the alternator, you may want to replace the battery as well, unless you're sure it wasn't the battery due to age, etc...
Rep it up
Rep it up
http://www.troubleshooters.com/dont_...ct_battery.htm
better safe than sorry
TallTom
57
Oct 14, 2025 05:16 PM
bigfrank
Oct 1, 2015 12:51 PM
