problem with spark plugs
Old Aug 31, 2007 | 06:07 PM
choiiiiiiiiiii's Avatar
so i went out and bought ngk plat spark plugs and replaced em.
they were way past due, and the ignition coils were looking pretty nasty. i took out some of the copper crap inside and cleaned what i could. after install, i take it out for a spin and it feels a little sluggish. after a mile, i got a blinking service engine light. ?? any advice...? i know i need new ignition coils but untill then what coudl be a problem..
Old Aug 31, 2007 | 07:20 PM
TurtleHead
Get the codes read. It's probably a misfire code from a bad coil or bad spark plug install.
Old Aug 31, 2007 | 07:21 PM
bad spark plug install?? i dunno hwo that is possible, because its just screw out screw in.
Old Aug 31, 2007 | 07:30 PM
slickrick's Avatar
try resetting the ecu...
Old Aug 31, 2007 | 07:32 PM
already did. now the engine light is off...however, i still feel it sluggish...and when i reverse, the engine feel slike its choking...and the car starts vibratign....
Old Sep 1, 2007 | 05:12 AM
Will's Avatar
How tight did you tighten them? It's typically hand-tightened until contact, and then another 1/4-1/2-turn. Sometimes if they are not tightened enough, the spark tip doesn't reach down into the combustion chamber as far in as it should.
Old Sep 1, 2007 | 05:40 AM
SoonerFan's Avatar
Cletus
i had the same problem
check the following -
make sure sparkplugs are tight
make sure coils are all connected
make sure all coils are connected to proper harness
Old Sep 1, 2007 | 09:08 AM
coils are connected to the proper harness? like the back coils in the back? front coils in the front? or the actual coils in the same spot they were in.
cause shoot, i did not put them back in the same spots...=/
Old Sep 1, 2007 | 10:36 AM
fixed. thanks
Old Sep 1, 2007 | 10:44 AM
2002 Maxima SE's Avatar
How did you fix it?
Old Sep 1, 2007 | 10:45 AM
wyche89's Avatar
that's probably what it was
Old Sep 1, 2007 | 10:53 AM
I've always put my coils back in the original sparkplug holes, but does that really matter? If so, why?
Old Sep 1, 2007 | 12:20 PM
i dont think it mattered.
lol all i did was redo everything and tighten everything real good. ??? doesnt make much sense because everything was on there pretty tight. but i dunno. car is kickin like it used to...feels great.
Old Sep 1, 2007 | 12:22 PM
oh and reset the ecu?
Old Sep 1, 2007 | 03:40 PM
NmexMAX's Avatar
dot dot dot ...
No reason for it.
Old Sep 1, 2007 | 05:22 PM
TurtleHead
The cylinders dont all fire at the same time.
I think they fire 1, 3, 5 then 2,4,6 but could be wrong.
Old Sep 1, 2007 | 05:30 PM
SoonerFan's Avatar
Cletus
fixed. thanks
yeah i had that problem with the rear coils...harness connected to wrong coil.
so they arent firing when the cylinder needs them too
Old Sep 1, 2007 | 07:08 PM
Right, but what does that have to do with putting coil one in place of coil five?
(No, I'm not suggesting crossing the plugs, just unplugging and switching coils).
It should have no difference. When you order replacement coils, they don't come assigned to a specific cylinder.
Old Sep 1, 2007 | 07:17 PM
SoonerFan's Avatar
Cletus
Right, but what does that do with putting coil one in place of coil 5?
to coils dont matter...the harness does
Old Sep 2, 2007 | 12:33 PM
NmexMAX's Avatar
dot dot dot ...
That's not the firing order
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
knight_yyz
Nov 6, 2015 02:34 PM
chernandez1278
Sep 16, 2015 01:18 PM
