Sponsored by:
Sponsored by: CARiD
00vi doesnt work after motor dek motor swap..
Old Sep 3, 2007 | 04:55 PM
DcMaN's Avatar
Anyone have any ideas why it doesnt work, the rod moves perfect manually, like when i push the actuator lever in, but whenever i try to power it electronically with or without the rpm switch it does nothing. What could be the cause of that ?
Old Sep 3, 2007 | 05:45 PM
matty's Avatar
Get a new upper manifold already you cheap **** !!!!! its been like a year
Old Sep 3, 2007 | 06:17 PM
DcMaN's Avatar
haha nooooo i want to know why it wont work. Everything else is fully functional.
Old Sep 4, 2007 | 11:10 AM
97_Roadrunner's Avatar
Where did you hook-up your vacuum lines?
edit: Pics would be helpfull.
Old Sep 4, 2007 | 08:01 PM
KRRZ350's Avatar
Shouldn't matter. I would start by swapping the swirl valve selenoid with the vi selenoid, seal up the o-rings and see if the selenoid is the problem before buying a whole new intake, but I don't know what has been discussed in the past...............
Old Sep 5, 2007 | 02:45 AM
Curt's Avatar
Quick way to check to see if the 00VI's internal vacuum actuation system is functioning correctly is to (temporarily) connect a vacuum line to the solenoid nipple. As soon as the engine fires up the power valve should actuate.
FlaMark
Jan 8, 2016 07:21 AM
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
raffivegas
Aug 23, 2015 09:54 PM
kenc15
Aug 5, 2015 08:29 AM
