15.6 @ 90 (haha?)
15.6 @ 90 (haha?)
Went to Pittsburgh Raceway Park last night. Humidity was so-so, coldest part of the night got down into the high 70's. Had ~3/4 of a tank of gas, back seat out, trunk empty, etc. (basic track weight reduction). Had the front tires aired down to about 26 PSI.
Overall, bad night to be racing. My buddy with a turbo Regal that had 2 nights previous run a 12.4 could not best a 13.0 (ran 13.2 all night until his last run). I got 3 runs in, a 16.6, a 16.4, and a 15.6. Something is wrong, no?
On the 15.6 run, I actually just missed a tie with a GTP who ran a 15.5 @ 90 (with u-bend removed and an intake). A GTP with a guy who's drag raced many times before running that kind of a time? Yeah, something's off.
Personally, I can name a million different things wrong with my car that put me off. The two 16-second runs it didn't click, but I would launch at about 1500 and have no power off the line until about 4k, and even then it was sluggish. I was pulling 2.7 60's. It wasn't until I went to park and the car nearly stalled that I figured it out: my intake was coming apart. The two flex sections on my intake were completely apart and separated about 2 or 3 inches. Good for power? Probably not. I duct taped that together the best I could, but ended up with a tube of duct tape about 1/2 the ID of the intake flex sections with tape on the inside sticking every which direction. That's when I proceeded to run a 15.6. That run had a 2.466 60', but I also launched just off idle and I doubt the duct tape was helping my power any.
So, that needs fixed. Need to hook my transmission goodies up again. Still haven't bested my 15.5 @ 90 since I got the 00VI, kind of depressing. Had some fun on the highway on the way home and still managed to embarrass some Civics, but alas.
Run 1:
R/T ... .665
60' ... 2.684
330 ... 7.233
1/8 ... 10.865
MPH ... 67.93
1000 ... 13.981
1/4 ... 16.661
MPH ... 83.55
Run 2:
R/T ... .871
60' ... 2.721
330 ... 7.620
1/8 ... 10.840
MPH ... 69.03
1000 ... 13.888
1/4 ... 16.483
MPH ... 87.48
Run 3:
R/T ... .456
60' ... 2.466
330 ... 6.713
1/8 ... 10.197
MPH ... 71.11
1000 ... 13.154
1/4 ... 15.684
MPH ... 90.10
On the 15.6 run, I actually just missed a tie with a GTP who ran a 15.5 @ 90 (with u-bend removed and an intake). A GTP with a guy who's drag raced many times before running that kind of a time? Yeah, something's off.Personally, I can name a million different things wrong with my car that put me off. The two 16-second runs it didn't click, but I would launch at about 1500 and have no power off the line until about 4k, and even then it was sluggish. I was pulling 2.7 60's. It wasn't until I went to park and the car nearly stalled that I figured it out: my intake was coming apart. The two flex sections on my intake were completely apart and separated about 2 or 3 inches. Good for power? Probably not. I duct taped that together the best I could, but ended up with a tube of duct tape about 1/2 the ID of the intake flex sections with tape on the inside sticking every which direction. That's when I proceeded to run a 15.6. That run had a 2.466 60', but I also launched just off idle and I doubt the duct tape was helping my power any.
Run 1:
R/T ... .665
60' ... 2.684
330 ... 7.233
1/8 ... 10.865
MPH ... 67.93
1000 ... 13.981
1/4 ... 16.661
MPH ... 83.55
Run 2:
R/T ... .871
60' ... 2.721
330 ... 7.620
1/8 ... 10.840
MPH ... 69.03
1000 ... 13.888
1/4 ... 16.483
MPH ... 87.48
Run 3:
R/T ... .456
60' ... 2.466
330 ... 6.713
1/8 ... 10.197
MPH ... 71.11
1000 ... 13.154
1/4 ... 15.684
MPH ... 90.10
Sounds like the track was not prept... this has happened to me before. When you took off at idle it hooked up better. Whenever this happens put your tires to 18-20 psi. It will help your 60 foot alot. You said your friend couldn't get down his times either... Yea sounds like they dint do anything to it.
i'm assuming your car is auto with those 60' times, correct?
nothing can be blamed on weather conditions for your area yesterday, they were pretty good. hopefully it's the car and not the driver (driver is much more difficult to fix).
The track was prepped better than the track I usually go to, but not great, either. Yes, Neal, my car is auto. I think the problem with my 60' is that my power is down because of the screwed up intake. Once I get the intake fixed we'll see what happens. I plan on going there once more before the end of the season.
Hey now. That would have slowed me down due to the extra weight
In all seriousness, I'll get a good intake on and hope for a 14.9 on a cold night. It's sad that just patching up a broken one netted me a .8 second improvement. Oh well. Time will tell.
Damn man, that sucks. I know how you feel though. When my car was stock, the one time i actually had time to make it to the track to get some baseline runs before i put my intake and y-pipe on, the car starts missing like crazy under load..turns out my plugs were toast.
Good luck on 14's. I think you should definately be able to get into the 14's with your mods! if you can get a good launch and fix any problems i think your maxima is capable of a 14.7.
With the auto and the lack of good tracks (the one last night was decent but was a 2 hour drive!) I'm not sure a 14.7 is within my reach with these mods (at least not without tuning) but a 14.9 shouldn't be out of the question. We'll see when I get these issues sorted out.
Streetz...I was actually running a weird intake setup. Two flex sections, stock midpipe, MAF, and an open cone. The two flex sections separated from each other, that was the biggest issue. I found a longer flex section to replace one of them and the cone filter is being ditched in favor of the stock air box then (including the snorkel). For right now, though, I put my short ram piping back on.
Put the short ram back on and the car pulls like no other
The part-throttle torque at low RPM's for driving around town is a little disappointing, but that's excusable until I get all the stock stuff on.
Originally Posted by Tatanko
Get to the track
Test and Tune: 12$ for entering and running, 6PM-midnight. Fr/Sat/Sun.
Maybe I will choose my night wisely (wrt-DA).
Originally Posted by NmexMAX
6PM-midnight.
(even when its 100 during the day, its common to see low 60s at night)
Nice man, good thing its the car and not the driver who is broken..broken driver is a lot harder to fix then a broken car
NmexMax get to the track too!!! I wanna see what all that dyno time and tuning will do
I am betting deep 13's assuming you dont have the broken driver mod heh
12$ for test an tune is crazy, for here test and tune is 75$ and its always full. I think it goes from 6 or 7pm too midnight too.
what? how is that even possible lol. the most expensive track I've ever been to (RT 66, one of the best and fastest tracks in the country) is like $35 - I've run at actual 2 day events there and only paid $55...
$35 is the most expensive I've been to. Most are like $20 on Friday nights.
heh yeah, i cant remember what if it was either street legals or test an tune, but the women told me 75$ so i was like..uhhh nvm high school haha...i think even high school is 35 or something. It is canadian, mission is known to run fast too.
Just checked it was $65..still not much cheaper. haha
that includes driver and entry fee w/e.
it was only 10 bucks to race at the tracks back home for me, but here in NZ its way up there, usually $35 dollars a day to $50. what gets me is at one track I have to pay an extra 20 to get in, on top of my race fee ?
its all good, and get that car into the 14's, you know she can do it !
I at least have somewhat of an explanation for mine, but that is very weird. In my case I have a 4th gen TPS on a 5th gen throttlebody and just sort of eyeballed it whenever I put it on.
BrandonCause
Sep 20, 2015 10:20 PM
If you enter in any events, then the entry fee can get pricey (85$)
