Stillen RSTB vs. Stillen RSB, and Stillen RSB vs. Addco RSB
Guys and Girls,
I need forums opinions on 2 things.
I am thinking about purchasing Stillen RSTB or Stillen RSB,
which one is better for the max to improve the car handling?
The second thing is the good and bad of the Stillen RSB vs. Addco RSB, because addco is $100 cheaper compare to stillen.
But Stillen RSB looks so much more solid compare to Addco RSB.
I heard, by installing Addco RSB you will loose the spot for the jack.
These are the current prices I got from Phuong
Stillen FSTB $174 back ordered for 1 week
Stillen RSB $234 (I think)
Addco RS from custommaxima.com $145
Stillen RSTB $202.5 from Avalon racing
Thank you
Thank you
Where did you hear this Baloney?!!!! Who ever said this to you needs to reinstall his RSB the correct way b/c it doesn't go anywhere near the jack spots....
BTW......
I have the Addco rsb and it does wonders around the corners.
Stillen is supposedly better b/c it's adjustable and can be tighten one more level compared to the Addco... But I still think it's way overed price for such a little improvement.
As for the RSTB, it's suppose to do the same as the FSTB but ppl say they don't feel a thing after installing it.. Just stick with a Stillen RSB and if you don't have a FSTB yet, get that as well.
BTW......
Originally posted by RBa
[i]
[i]
[i]
[i]
The Stillen bar I think can be moved out of the way, so you can still use the rear beam as a jacking point.
Tanmann9
2000 Maxima SE black automatic
Enkei RS6 18" wheels
Nitto NT555 tires
Pioneer CD receiver and changer
AE door sills
Powered by Nissan seatbelt covers
there a stillen rstb on ebay
theres a rear strut tower brace on ebay, i came upon it while surfing, you can find it when you go to SEARCH and type in STILLEN. i think new or used they will perform the same and you can save more money. the stillen line of things look better and sturdier and since most of his stuff is race-developed it should be a little better, but the prices are outrageous. i got the stillen RSB and its awesome. hope this helps.
Originally posted by Tanmann9
Actually, when you install the Addco RSB, you lose the rear multi-link beam as a jacking point, ie, you can't jack the whole back up because the bar gets in the way. You can still jack the back from the left and right sides.
Tanmann9
Nitto NT555 tires
AE door sills
Tanmann9
Nitto NT555 tires
AE door sills
BTW, you should put all your mods in your sig so that you don't have to type/copy&paste it every time.
Tanmann9
2000 Maxima SE Black Automatic
Originally posted by UMD_MaxSE
you still have a half inch or so clearance to jack that car up if your RSB is under the rear beam.... Just don't jack it up using the RSB as a jack point....
There is still sufficient room on the beam ends at each wheel to use jack stands. Haven't tried it yet, though, coz' I haven't had cause to raise the rear since I installed the bar!
Just toss the block in the trunk and make sure any garage I might take the Maxima to uses it; I always insist on checking the jack points a strange garage uses any way.
BTW, it makes for an amazing improvement in handling and feel through corners. Can't wait for the FSTB.
So combination of FSTB and RSB supposed to give the best combination for the money.
At this moment I am looking @
Stillen FSTB $174 plus ship
Stillen RSB $234 plus ship
all prices from phuong www.eatricezone.com
So I'll not losing any jacking point at the side of the car, only the rear multi link beam as a jacking point, or there is a little bit of clearance.
I will get both of them, my check from IRS just arrive
Thank you
Thank you
Thank you
Thank you
Rear Bar Comparisons
Stillen RSTB
Advantage
makes your rear end tighter. (of your car . . .
Dis-Advantage
Goes thru the trunk, making less trunk space.
The Maxima has a 'built-in' RSTB, so to speak. The speaker shelf. It's position helps to keep the rear shocks in tandem.
Most people say that the RSTB doesn't really do that much, perhaps because of the rear speaker shelf mentioned above.
Stillen RSB
Advantage
Makes your rear end tighter.
Easily Adjustable.
Does not take away trunk space.
Leaves your center rear jack point so you can still jack up the rear of the car from one jack point.
Dis-Advantages
The bar is hollow.
Addco RSB
Advantages
Adjustable.
Solid thick bar.
Dis-advantages
Takes away mount point for rear of car. You have to jack up 2 sides to fully lift the rear of car.
Not so easily adjustable, but it is.
I have the ADDCO
DW
Advantage
)Dis-Advantage
Stillen RSB
Advantage
Easily Adjustable.
Dis-Advantages
The bar is hollow.
Addco RSB
Advantages
Adjustable.
Solid thick bar.
Dis-advantages
I have the ADDCO
DW
Hei dwapenyi
Thank you for your reply, it was great explanation.
I really like the way you explain this concept, so I drop the RSTB and move on with the sway bar and Stillen still my choice.
I am ordering it right now, and I can't wait.
hmmmmmmm
yummy
hmmmmmmm
yummy
Re: Rear Bar Comparisons
Originally posted by dwapenyi
. . . Most people say that the RSTB doesn't really do that much, perhaps because of the rear speaker shelf mentioned above. . .
Norm
Re: Re: Rear Bar Comparisons
Ok then. Perhaps not for the speaker shelf part.
So then, Norm, do you have a beer buddy named Cliff Claven who hangs at your local waterhole named Cheers?
Say hello to Dr. Frazier Krane for me. He's one cooky psychiatrist. I hear he has a radio show in Seattle now. .
DW
DW
Originally posted by Norm Peterson
The major reason a RSTB doesn't do much for a Maxima is because the rear wheel camber is not sensitive to movement of the rear strut towers (it's determined by the stiffness of the beam axle instead). What you do gain from a RSTB is some overall chassis stiffening that can help your efforts at chassis tuning for at the limit cornering at an autocross or road course but which offers minimal gain for the street and about zero help at the dragstrip.
Norm
Norm
Re: Re: Re: Rear Bar Comparisons
. . . So then, Norm, do you have a beer buddy named Cliff Claven who hangs at your local waterhole named Cheers?
Norm
05RLS2
Apr 14, 2016 11:49 AM
Stagnet04
Sep 14, 2015 11:28 PM
