coolant drain plugs
Originally posted by camaro1698
What the best way to loosen the coolant drain plugs on each side of the motor? I can barely get my hand in there. Is there a special tool that is used to lossen them because they seem really tight!!!
Huh..
Originally posted by Daniel B. Martin
Those engine block drain plugs are so difficult to reach that most people don't bother with them. You can do a good cooling system flush by repeated fill/run/drain cycles using the radiator drain only. Some people prefer to idle the engine with a garden hose running at "trickle" stuck in the open radiator fill cap, producing a constant overflow.
Thanks for another gerat idea.
SuDZ
Forge277
Jun 13, 2016 09:26 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
