anyone got an audio wiring diagram?
Old Aug 17, 2001 | 05:10 PM
djslinkyz's Avatar
for a 92 gxe w/ active speaker system (non-bose)
thanks
Old Aug 20, 2001 | 08:11 AM
97SEMAX's Avatar
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
you must have adobe acrobat reader installed to view a .pdf file so install the go to the above site.
Adobe acrobat reader:
http://www.adobe.com/products/acrobat/readstep.html
-97semax
Old Aug 20, 2001 | 03:09 PM
djslinkyz's Avatar
thanks so much
Old Aug 21, 2001 | 05:18 AM
97SEMAX's Avatar
Originally posted by djslinkyz
thanks so much
No Problem
Old Sep 7, 2001 | 09:27 PM
Jaybird180's Avatar
-97semax
Here's one: Rear amp bypass. Color code is not the same as what's in the Haynes POS
Old Sep 8, 2001 | 08:41 PM
djslinkyz's Avatar
taken from Matt's webpage:
once you remove the amp, you'll have a connector with a dozen or so wires. the ones you need to connect are:
Large/ Small
Green/ Black-pink
Yellow/ black-yellow
Orange/ Orange
Blue/ Light Green
These are the same wires you unplug from the amp. just cut them about
2-3" away from the end of the connector, so you can reconnect the amp
whenever you sell the car. There will still be a few wires left on the
connector (power, ground, etc) just leave those connected to the thing,
that way you don't have to worry about loose power wires hanging around
back there. It will all seem a lot clearer when you get back there
inside the trunk. btw, the easiest way to do this is to just grab a
handfull of butt connectors and get on your back inside the trunk. just
leave a leg hanging out so someone doesn't come along and shut you in!
Old Sep 9, 2001 | 09:17 AM
Jaybird180's Avatar
Rear amp bypass color codes
I have that information. I eliminated 5 of the 11 wires by tracing, and did trial and error to find the correct 4. They are: Yellow L+; Lg Orange R-; Green R+; and yel/grn L-.
You take these 4 wires and connect them directly to the speakers in your rear deck.
Old Sep 15, 2001 | 02:28 PM
Jaybird180's Avatar
Re: Rear amp bypass color codes
I need someone to confirm the Right side for correct phase. I may have listed them backwards. If anyone is following this post, if you get weak bass, turn your fader to the rear full, and balance left and right. If bass is better to either side, and weak in the middle, then I have them backwards. I found this out when I had to redo something w/ my wiring. Don't know if I screwed up w/ the other(head) end or not. But you have all the info. to get the job done.
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
