Found Exhaust Leak.......Any Suggestions?
Old Aug 19, 2001 | 08:46 AM
NISSMAX2K1
After buying some ramps, laying underneath the car for a good 20-30min, and my fiance reving the motor, I found the exhaust leak. It is coming from where the y-pipe connects to the rear manifold. Any suggestions on what I can do to try and stop the leak. Thank You.
Old Aug 19, 2001 | 10:28 AM
MaineI30's Avatar
i have always gotten a little putt-putt from my Cattman Y .. so if there are any easy solutions I'm all ears, too...
but everything's tight on mine
Old Aug 19, 2001 | 12:05 PM
UMD_MaxSE's Avatar
Got Bent?
how did you know to check for the leak? Was your exhaust noisy? You did replace the gaskets when installing the y-pipe right?
Old Aug 19, 2001 | 01:10 PM
NISSMAX2K1
There was a sound coming from under the car, not a hissing noise, more like a ticking fluttering noise, it's kind of hard to explain in words. I had the stillen flex pipe removed and replaced with a stainless steel interlined flex pipe and the noise was still there. I watched my mechanic put the pipe it on from start to finish and he used all the new gaskets supplied with pipe. I took it back to him on 3 seperate occasions to check for leaks and he said he he could find none. But when you are in a shop with other noises going on and fans blowing and the car running it is kind of hard to hear or feel a leak. It is quiet were I live so I decided to o some investigating myself.
Old Aug 19, 2001 | 01:33 PM
2000 SE's Avatar
Have you tried replacing gaskets yet? Maybe if you just loosen the front bolts (take the bind off the pipe) and then simultaniously tighten the front/back.....
Just trying to help
Old Aug 19, 2001 | 05:17 PM
WILLSE's Avatar
put 2 gaskets on if u have to! i have had probably 10 leaks in my exhuast at differet times gaskets have always been the problem!
Old Aug 19, 2001 | 06:36 PM
BigDogJonx's Avatar
If you replaced the gaskets, replace them again. I would probably just make my own gaskets. You can buy a sheet of gasket like paper from a major auto-parts store. If the gasket is too thin, either get a thicker one or double up on it and make sure the gasket is crushed and tight when you bolt the Y-pipe and manifold pipe together.
Dixit
Old Aug 20, 2001 | 06:01 AM
NISSMAX2K1
Thanks guy's for all the suggestions. Last night when I got home from work I put the car back on the ramps and went to looking and try to tighten. I was at a different angle last night, I was looking and feeling around the rear manifold connection......guess what I saw. I saw the rear gasket sticking out between the y-pipe and the manifold connection. I was excited but yet was very angry. I paid $85.00 to have this thing put on buy a professional and this is what I get. I will be at his shop first thing in the morning. I am glad that it is a problem that can easily be fixed. Now all I have to do is gets some gaskets. Thanks again for the suggestions.
lowpost99
Oct 26, 2025 06:53 PM
pjgreek
Sep 9, 2015 09:30 PM
Hdnseek
Sep 9, 2015 05:55 AM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
