question fo DBM - re: wheel bearing
I was just wondering what the symptoms of a bad wheel bearing would be... and what would happen if I didn't replace it? I am hearing a pretty loud roaring noise in the front driver side wheel area - the noise gets progressively louder with speed.
Also, when the wheel bearing is replaced , do they usually do a wheel alignment as well?
97 gxe w/ ~ 61k miles
Thanks.
Thanks.
Thanks.
Thanks.
If the front wheel bearing is replaced according to the factory service manual procedure the steering knuckle is removed from the vehicle, serviced, and installed on the car. A wheel alignment is necessary.
If the front wheel bearing is replaced with a special time-saving tool such as the Old Forge "Hub Shark" http://www.thetoolwarehouse.net/shop/product2993.html or the OTC "Hub Tamer" http://www.mile-x.com/otchubtamer.html the steering knuckle is serviced on the vehicle and no alignment is needed.
Thanks.
Thanks.
- A pebble caught in the caliper area, rubbing against the rotor.
- A stamped steel splash shield which has been bent so that it rubs against the rotor.
- A brake shim which has moved out of position and is rubbing against the rotor.
These problems, if present, are easy to find and inexpensive to fix.
Originally posted by Daniel B. Martin
A roaring sound could come from a failing wheel bearing, but look for simple causes first.
Thanks DBM...
My front bearings went on my 97...
Basically I was driving and a metal on metal noise could be heard from the front wheel. It got louder as the day progressed. The sound would go away/soften whenever I turned the wheel. Anyway, I took it to the dealer the very next day and they replaced the wheel bearing and they did do an alignment on the car. I had it back in a couple of hours so I guess it was not a major repair. I can't tell you how much it cost cause the dealer replaced it under the nissan 3 year warranty. Hope this helps.
Ed
Ed
FanaticMadMax
Aug 10, 2015 08:55 PM
