Where can I buy sheets of Diamond cut plastic?
Old Aug 21, 2001 | 09:07 PM
emax02's Avatar
I want to make my tail lights diamond cut but need to now where to buy this stuff? Does it exists in sheets? Today I installed red clear tail lights on my 95 and mastered the art of removing the covers on my oem and APC peices, I think I could easaly make dimond cut tails if the sheets exist. Any help whould be greatly appreciated, thanks!
Old Aug 22, 2001 | 07:33 AM
Lime's Avatar
I think it's just covers for fluorescent lights...you should be able to get it at home depot or lowes. SprintMax would be able to answe better than I, as he is the master.
Old Aug 22, 2001 | 08:54 AM
mtrai760's Avatar
'Trynna' is not a word
What Lime Said I got mine at Home Depot, but most major hardware stores should have it in the lighting section. Cutting it is a b*tch though! Good luck.
Old Aug 22, 2001 | 12:37 PM
Lime's Avatar
use a dremel! Copy the pattern onto the plastic with a marker or something and then use onna those circular cutter bits on the dremel.
Old Aug 22, 2001 | 01:08 PM
Kevin Wong's Avatar
Heat the plastic a little before cutting too. It'll prevent the plastic from cracking are you cut. Also, you can heat the plastic to bend in order to fit the housing better. I'm going to redo mine once I can find some better plastic material. My flourecent light covers I bought at Home Depot look a bit grey in comparision to the reverse light.
Old Aug 22, 2001 | 03:05 PM
emax02's Avatar
Thanks a lot for the info guys! I will do this project this week.
Old Aug 22, 2001 | 05:13 PM
NickStam's Avatar
Ehh, i am the master.
Old Aug 23, 2001 | 02:51 PM
Kevlo911's Avatar
Kevlo for President
yes i would say u r the master, everytime i look ur tails i get jeaulus., i am afraid i will break my tails or i would do it.
shilov
Feb 19, 2024 09:40 PM
jsmith24
Feb 1, 2016 12:35 AM
Junebug1701
Sep 25, 2015 01:54 PM
blakkheartt12
Sep 17, 2015 08:11 AM
jerrod99_se-l
Sep 15, 2015 08:55 PM
