HELP -- Grille removal
Old Aug 28, 2001 | 07:57 AM
smackdownGTR's Avatar
Hey guys! I need help removing the grille on my 98 max. I know there are 2 tabs on each side of the grille when I lift up the hood. How can I get a screwdriver into the limited space to turn the tabs without breaking the grille.
Old Aug 28, 2001 | 08:25 AM
Daniel B. Martin's Avatar
Raise the hood. Locate two plastic fasteners in the upper corners of the grille. They look like black square slotted screw heads. Insert a small flat-blade screwdriver into the slot and turn CCW 1/8 turn to release the clip. Gently tug the grille upward and outward. Elapsed time, 30 seconds.
Installation is almost as easy. The two plastic fasteners stayed in the car. Use a small pair of pliers to squeeze the legs together, and remove them. Insert the square heads into the hole in the grille, working from the back of the grille. Turn 1/8 turn to click into place. Place the grille into the vehicle body, taking care to line up the locating pins near the lower edge of the grille. Gently push those two plastic fasteners into their respective mounting holes. Snap! The job is done. Elapsed time, 60 seconds.
Old Aug 28, 2001 | 08:33 AM
Thanks alot !
Old Aug 28, 2001 | 06:01 PM
sleeper's Avatar
grill removal
i just wiggled the top of the grill and pulled it out. it just snaps in and out.
REDinLV
Aug 15, 2024 12:30 AM
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
ricky7780
Sep 24, 2015 06:50 PM
