Why Me? Why Again? D.B. Martin? Any thoughts?
Ok, so Saturday my alternator died. I got jumped a couple times and got home. Sunday I got a new alternator. I pulled out the battery and had it charging while I replaced the alternator, which took a few hours. After I did the install everything seemed ok. I was driving it all around fine. It is now Monday night. Actually very early Tuesday morning, and as I was going up an onramp, my headlights went out then sort of made their way back on. My battery light came on too, then a blinking airbag light when I was about to stall. What the heck is going on? Everything seemed fine when I did the new alternator. Any ideas what could have gone wrong? Why is the thing dead already?
Re: Why Me? Why Again? D.B. Martin? Any thoughts?
Re: Re: Why Me? Why Again? D.B. Martin? Any thoughts?
Originally posted by emax95
Check all of your connections and have your battery tested.
All the connections to the alternator are correct, and to the battery. I guess when I get a new alternator I'll buy a new battery. I don't get it. It takes charges fine. It was charging fine...when the alternator worked, it worked fine.
Originally posted by medicsonic
Did you test BOTH the batery and the alternator? Go to pretty much any automotive store, and they have the testing machines on site.
Greg, what do I look like...a himbo?
Re: Re: Re: Why Me? Why Again? D.B. Martin? Any thoughts?
Idea #2) You said your battery charges fine. That is not a guarantee of a good battery. The hallmark of a good battery is that it takes a charge and holds a charge.
Many auto parts stores offer a no-cost charging system test. This is done with an electronic tester and takes only two minutes. Please have this test performed.
Re: Re: Re: Re: Why Me? Why Again? D.B. Martin? Any thoughts?
Originally posted by Daniel B. Martin
Idea #1) You said you got a new alternator. Is it really new or is it remanufactured? Some reman outfits do a first-rate job, while others are "spray and pray" ripoff artists. I've heard some horror stories about reman alternators and starters which lasted less than a week. Some were BOB (Bad, right Out of the Box).
Re: Re: Re: Re: Re: Why Me? Why Again? D.B. Martin? Any thoughts?
Originally posted by Enduro
Doesn't this charging system test only test how much charge the battery has at the moment and not the how good/long the battery can hold the charge? I was told this from the battery guy at Sears last night as I was looking into getting a new one.
a) Battery state of charge test
b) Open voltage circuit test
c) Battery load test
d) Battery drain test
REDinLV
Aug 15, 2024 12:30 AM
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
ef9
Oct 4, 2015 08:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
