How Do I Re-Aim Headlights???
Re: How Do I Re-Aim Headlights???
Originally posted by Empz
One side of my Headlights are kinda off ...
How do I re-Aim them???????
there is a white nut just behind the housing. you can turn that to lower the lights. use the search and you can find more detailed instructions from kev.
if you are talking about the pass side light don't worry about reaming if its a little higher. i think it is the beam pattern designed by nissan. if you check my homepage you can see the pics of the lights against my garage door. on there you can see a "spike" that shoots up on the edge of the beam pattern.
hope this helps
Norm
Originally posted by mike-777
The car is under warantee - take it to the dealer, they can verify if it is out and fix it right for free.
No-brainer
No-brainer
Fewer people gripe about headlights if they would aim them to put the available light where it will actually do some good. Warning lights are for road hazards and radio towers.
Norm
Originally Posted by MaxBlu5
Are the foglights easy to adjust aswell? How do I go about adjusting them, removing the headlights?
See here for general aiming guidelines:
http://www.tirerack.com/accessories/...ech/aiming.jsp
http://www.danielsternlighting.com/tech/aim/aim.html
Originally Posted by Norm Peterson
I'm assuming that you're talking about your '01 20AE? The headlight pattern is intentionally not symmetrical. It is pretty close to the European pattern, which throws light up to the right to illuminate road signs but is cut off at horizontal for light to the left to keep from blinding oncoming drivers. Aim them against your garage door and use the horizontal cutoff of the beam as your reference. You might actually find that staggering the lights (right side aimed a tiny bit higher than the left) gives slightly better overall lighting. One of the small sockets in a metric 1/4" drive set will fit the adjustment nut. And you can also adjust the fog lights to make them more useful and not just for show. BTW, as delivered from the dealership, headlights and foglights are typically aimed too low unless you always drive around with the car fully loaded. So take this opportunity to aim the headlights and foglights to suit the passenger and cargo load that the car usually carries. Aiming the foglights higher will fill in where the low beams miss when they are brought up a little.
Norm
Norm
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
