Help! My front suspension is making weird noises (DBM and/or anybody)
Yeah! Everytime I apply the brakes from slowing down the front suspension makes a creaking sound. No, it's not the brakes. It might be my springs because I don't think it was installed properly by some guys at a speed shop. It sounds like something is breaking, kinda like a "crrrrkkkkkkkk" sound. Any suggestions or ideas what this may be? What should I do to get rid of it?
who did your suspension?
more than likely the problem both of you are having is as follows:
if you are getting a continous clank while driving straight?
the screw in the middle of the strut is loose..
if you are getting it while turning or backing up.. the strut housing is not lined up correctly..
ensure that the part on the strut writen OUT is facing the outside of the vehicle.. in other words.. it should line up with the part that bolts on to the car..
if you did it yourself.. you will have to pull the suspension down and re-align the car..
if a shop did it.. have them check to see if this is the problem..
Most likely, the springs are not aligned properly. I live in San Leandro,CA and the shop that did my suspension is at Industrial City,CA. I've actually had the Eibachs for almost 2 years now. That would take me at least 8 hours to get there. I'll probably just take it to a local shop and have them fix it.
This thread is ooold gah, but, I have stock suspension and mine does it, I heard alot of ppl talkin about this a while back, forget why it did it.. bad suspension mount or something..
It maybe something easy.
I just put on a FSTB a couple months ago. After the install a noticed a creaking sound from the front end, especially when front end would dive down under braking or lifting up under acceleration. I thought it must be something in the suspension. But I never noticed it b4 I put on the FSTB. So I took it off, and no more creaking. Turns out the FSTB was rubbing on some of the emission hoses. So I bent them out of the way a bit, re-installed the FSTB and all is well so far. Maybe this helps
Kevin
boomerbrian
Nov 8, 2015 05:10 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
