Ordering parts TODAY. Need a few quick answers.
Old Sep 18, 2007 | 09:57 PM
Black2000maxima's Avatar
Im a long time member here & I know the rules about posting crap thats already been asked & to search,etc,etc. Which I did and came up with nothing since the threads I was trying to view were either deleted or restricted
So here are my simple questions that Im sure have been answered plenty of times before....(prepares to be flamed)
1) Energy Suspension Motor Mounts & Subframe bushings - Do they work for 2000 auto's?? My stage 3 VB mod has absolutely destroyed them. And the car is now stalling if I stop to fast
2) I have the standard o2 Sensor code for Bank 2 Sensor 1(p0140). I have no clue what sensor this is or where to buy it cheapest. The real question being....where to buy it cheapest.
3)Lastly,Ive always had powerslots & hawks on the car since day one. They work great & all that other good stuff. But I really cant afford to replace the rotors & pads all the time from warping. Is there anything out there thats relatively cheap that can stand up to some spirited driving every once in a while,without wearing out in a few months?? Ill also be installing new Goodrige SS lines with these.
Thanks for any help/info.
PS- Ill take the ban if need be but I REALLY NEED this info ASAP. I was out on disability & broke for a long time,just got some money to fix the car & I need to get it done before it gets any worse(which it has been) or Ill be forced to sell it.
Old Sep 18, 2007 | 10:48 PM
spdfreak's Avatar
I have no answer for your first question.
As fo your second queation, theres a diagram somewhere here in this section that shows a diagram of the sensors in the exhaust.
As for the third question, my advise would be, that you should go with a rotor thats not drilled or slotted. The drilled and sloted rotors chew up the pads quicker. I'm still on my oem rotors and cut them when they warp. Take off a couple of thousands of an inch just to regain a smooth straight fresh edge. (Use a laith.) (You can have a brake shop turn the rotors but they take a big chunk off.)
If your going to replace the rotors I would guess you should go with brembo blanks which can be found in the group deals section.
Old Sep 18, 2007 | 10:53 PM
MaxBoost925's Avatar
Drug Money
ES Motor mounts don't work for the auto (rear)
Old Sep 19, 2007 | 03:03 PM
RLW001's Avatar
This should help with the O2s.
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
I found Pinnacle Nissan has GREAT prices for O2 sensors (226A1-5Y701) $108.47
http://www.nissanparts.org/oem_parts.html
Old Sep 19, 2007 | 04:37 PM
NmexMAX's Avatar
dot dot dot ...
Odds are there is another problem regarding the staling issue.
I have one
http://forums.maxima.org/showthread.php?t=535943
Originally Posted by Cattman
- Energy Suspension Motor Mount Bushing, rear only (1 bushing) for 00-03 Maximas/I30s/I35s with auto transmissions only (check with us on fit); reg. $60, only $46.99.
The front can also be used (MT), it is not a 100% direct fit, but you have to remove the electrical connector.
http://forums.maxima.org/showpost.ph...1&postcount=15
Old Sep 19, 2007 | 08:57 PM
ktranne's Avatar
NOOB
too late? repost? anyway here's o2:
http://forums.maxima.org/showthread.php?t=402075
Old Sep 19, 2007 | 09:40 PM
CHINO22's Avatar
I've seen some bosch sensor for around 80 ..I dont know if there any good!!!
Old Sep 19, 2007 | 10:32 PM
Thanks for the replies guys. I really appreciate it. I got in touch with Vadim & Im getting a full set of automatic urethane filled mounts.
As far as the O2 goes...I figured it was one of the more expensive ones Just my luck.
And regarding the stalling Nmex,the car only stalls if I get on the brakes hard,other than that it runs just fine. Didnt start doing this until the motor mounts got REAL BAD...
Old Sep 20, 2007 | 12:27 AM
lalaMAX's Avatar
off topic.. but all the yahoo and google seems not working with the link from this fourm...
MikesChevelle
Nov 23, 2024 11:17 AM
doctorpullit
Apr 5, 2017 12:59 PM
fulloboost
Sep 12, 2015 08:03 AM
N2deep
Aug 16, 2015 08:30 PM
kirkhilles
Aug 8, 2015 10:53 AM
