clutch pedal to the floor :(
Old Sep 24, 2007 | 07:31 PM
seshead's Avatar
what is the cause for this? Is the slave gone bad? Is any of it covered under warranty?
SUcks that I have this problem at 114K
Old Sep 24, 2007 | 08:15 PM
justinny's Avatar
nothing is covered under warranty at 114 k lol
does the clutch master have fluid?
if not, fill it and try to bleed it (at the slave)
if it bleeds and the pedal comes back, pull the dust boots off the master and slave and check for moisture, replace if its leaking
if the pedal doesnt come back check for large leaks under the boots and check the lines/hoses
if its full, check the linkages and pushrods, or the master might have gone bad (internally bypassed)
Old Sep 24, 2007 | 08:37 PM
A33 VQ30DEK's Avatar
you probably have a leak in your clutch master cylinder, and therefore air has got in the line.
Old Sep 25, 2007 | 05:34 AM
seshead's Avatar
the cylindr has fluid at the lowest mark, there are no leaks around the car.
I guess i could try to top off the fluid level to see if that works.
I have warranty to 160 k bumper to bumper (extended warranty)
thanks for your input guy
Old Sep 25, 2007 | 05:45 AM
ghostrider17's Avatar
Good advice from above.....checking for leaks etc.
Limp it to the Stealer, and put that warranty to work!!!
gr
Old Sep 25, 2007 | 04:43 PM
MetalBlueMaxx's Avatar
You didn't adjust your clutch position did you? I did this and it would go to the floor and was like I had a blown clutch because I over adjusted it.
Old Sep 25, 2007 | 07:31 PM
00SEMAX19's Avatar
If you opened this, you will loose your pedal untill rebleading system
Old Sep 30, 2007 | 09:14 AM
phillyse's Avatar
happened to my 540 once...the bleed screw was open and fluid all leaked out
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
