fidanza flywheel....
Fidanza flywheel, not worth it unless you replacing the clutch anyway AND have additional performance mods.
And also will bog down on a hard launch until you learn how to fight it. The decrease rotating mass takes away from the inertia of the spinning engine, thus allowing it to slow down faster, as well as rev quicker. This is why it helps more if you have more mods...
I had a stock.....went to fidanza........went back to stock.
yes the way the car takes off is changed as well. a good mood to go along with this is a lighter crank pulley.
im currently installing a new clutch, still waiting on my part to come in, my whole car engine is stock? but my flywheel is a bit worn, what do you guys recommend. i would rather do something to it now now that i have it out instead of spending another two hours some other time just for the flywheel.
would this fidanza flywheel be a good option?
To the OP, even if you can't afford the fidanza right now, you must at least shell out the $40-50 to get your stock flywheel machined.
Reducing rotational mass increases acceleration at lower speeds, meaning you'll notice a huge difference in 1st gear, some in 2nd, and not much if any in 3rd. 5-speeds have much less rotational mass over auto's as well, that's one of the reasons they feel so much faster. After doing my fidanza it made playing around in 1st gear SOOOO much more fun, it turned it into a neck snapping beast, allthough I did a y-pipe at the same time on my car I've driven a few max's that were 5-wpeed with just a y-pipe and the difference is night and day.
Just have a shop grind down your stock flywheel a little bit. Got mine done for only $35 and i do notice improvement in acceleration/revving. After a new clutch and lightened flywheel, I got my Quarter-mile traps from 98-low 99's to high 99-100 mph.
If money isn't an option then get the Fidanza FW, heck... get a Custom built turbo kit, a full 3.5 inch custom exhaust, standalone, etc... etc...
Do you by any chance have any before and after weights?
Maybe your clutch/pressure plate combo was a little lighter, generally the amount of material removed during remachining is peanuts, it needs to be put on a lathe and have alot of material removed, and from what I read on here there is no ok place to do this on a maxima flywheel.
OK....HOW ABOUT THIS ONE:
http://cgi.ebay.com/ebaymotors/XTD-P...QQcmdZViewItem
I know it aint a fidanza but what do you guys think anyways? Worth it? XTD...they make clutches also right? 13 pound flywheel, whats the weight of the Fidanza?
i had a similar question... i just bought a off the chart stage 3 cluctch off of ebay i did have my flywheel shave w/ almost 6-7 lbs taken off should i just get it resurfaced while i am at it or just upgrade to fidanza ... i do have full catback, y pipe, straight pipe, udp, and injen cai??? any help ll be appreciated
tnx..
tnx..
But to answer your question, no. The amount of material removed during resurfacing is next to nothing.
That's pretty impressive actually, that means if the link above is correct & the stock flywheel weighs 18+ you are right around the weight of a fidanza. Maybe that guy was wrong about being able to lighten the stock 4G flywheel...........
Incidentally, if you buy a replacement stock flywheel, the design has changed, and it has less material. I haven't weighed the two to see what the diff is, but I'll do that tonight and let you know.
BTW, does anybody know whether you're supposed to reuse the chromed, larger, thicker 8-hole flywheel hub reinforcement piece that was on the engine, or substitute the stamped, smaller, thinner 8-hole plate that came with the new flywheel? The Nissan service manager says he hasn't got a clue.
Kartiste
"Carry On, & Dread Nought"
Kartiste
Are you sure that the stamped steel part you received is for the manual flywheel? The automatic flex plate uses a similar design, although much thinner. Perhaps they sent the wrong one.. As far as I know, the manual flywheel still uses the heavy steel centering plate, the one that is shaped like a bowl, sort of.
PS I finally got in enough posts to be able to start a thread, so I started one on this, subject "Flywheel Installation Quandry". No replies so far. If you can help any, please reply over there.
Thnx
Kartiste
Thnx
Kartiste
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
