loss of 1st and 2nd gears
Old Oct 26, 2007 | 06:53 PM
abomb1987's Avatar
I been searching and asking around but the only thread that came up was a thread back in 2005 from the 3rd gen forum.
Heres my problem, about a 1-2 months ago my input shaft was going, it would make a (rur rur rur) noise when the clutch pedal was depressed. I was told by a .org member that my input shaft was on its last legs. But i continued to drive it, but one night i was on my way home from work and i was coming to a stop at a light, i went to put the car in 1st gear, and i wouldnt even go in, so tried 2nd gear........nope. Then i put it in 3rd, it went in perfect, so i drove it home like that for about 2 blocks till i got home, i parked it and still wouldnt go in 1st or 2nd, put it went it 3rd, 4th, 5th and reverse fine.
so im trying to figure out why, i believe the input shaft bearing is the cause of all this, but i just want to verify that its that. and before i take it shops and they try to charge me for something i dont need done.
1 other thing, i all ways kept up with the gear oil change, with reline mt GL-4 75w90
Old Oct 28, 2007 | 11:06 AM
VQ30DETT's Avatar
sounds like you need a rebuild. same thing happened to me, i believe mine was caused by bad clutch fork. my rebuild cost $1200
Old Oct 28, 2007 | 12:11 PM
Nealoc187's Avatar
SLOW
if it's making noise when the clutch pedal is depressed, it is not your input shaft bearing. your input shaft bearing doesn't spin when your clutch pedal is depressed.
does your shifter move over to between 1st and 2nd and you are just unable to move it up or down, or can you not even move it over to the left between 1st and 2nd?
Old Oct 28, 2007 | 09:28 PM
abomb1987's Avatar
i can move it in between 1st and 2nd but i just wont get into 1st or 2nd at all
oh and i meant when the clutch pedal is pressed it doesnt make noise, but when its depressed it makes noise (no foot on clutch)
Old Oct 28, 2007 | 09:47 PM
Nealoc187's Avatar
SLOW
depressed means the same thing as pressed so that's what was confusing me. so when it's NOT pressed it makes noise? in that case then your input shaft bearing is bad.
your problems getting in to 1st or 2nd could be related or they might not be. there are a number of things that could cause that. regardless, you need a rebuild or another working trans for each issue to be resolved.
Old Oct 28, 2007 | 09:57 PM
HomerMAC's Avatar
Donating i30 Owner
he lost me there for a while too..
I have the same problem, but soon as the sound became loud i stopped driving the car... am in the process of acquiring a tranny and DEK motor...
Old Oct 28, 2007 | 10:51 PM
kzoosho's Avatar
well i have a tranny with good internals but bellhousing is cracked well missing in spots. if you dont want your old tranny let me know i may take it off your hands.
Old Oct 29, 2007 | 12:37 AM
97maximaman's Avatar
On a related note, im having a kinda similar problem maybe you guys can help. When i press my clutch and go to put it into 1st or 2nd from a coast i get this rushing air noise. Almost similar to a blow off valve. Very hard to explain but i know its not normal, maybe its more of a winding noise im not really sure. It's rarely notchy but at times i notice it makes the noise only when the shifter is notchy. Any ideas?
Dont mean to jack the thread btw.
Old Oct 29, 2007 | 09:08 AM
Snypa's Avatar
sounds like you have turbo without even knowing.
Old Oct 29, 2007 | 11:22 AM
Haha, made my day, im gunna go drive my newly turboed car. Well if anyone else has any other idea let me know, otherwise i'll be do a 6spd swap when i do the 3.5 swap.
Old Oct 29, 2007 | 02:32 PM
iDuty's Avatar
If you are moving at more than a creep, you might be hearing a shaft spinning up as a syncronizer does its job. I'd say it is pretty normal if it is subtle. If it is loud something may be going bad. The MT experts here will surely give you a better answer.
Old Oct 29, 2007 | 03:13 PM
abomb1987's Avatar
how much are you willing to sell your used tranny with the cracked bell housing
and ill be more then happy to give you my old tranny if you dont want it
Old Oct 29, 2007 | 03:14 PM
abomb1987's Avatar
yea my bad i lost my self there to
Old Oct 29, 2007 | 06:10 PM
kzoosho's Avatar
Well i was going to use your tranny for the bellhousing since my tranny was rebuilt last year. Its in good shape as far as gears but the bellhousing is cracked to hell. i mean i dont know. pm me and we can work something out.
TallTom
57
Oct 14, 2025 05:16 PM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
zmcneely13
Sep 26, 2015 02:26 PM
