No crank/no start help!
I have a No start/NO crank issue on a 95 Maxima GXE, This first started about two months ago, the car is my wifes car, anyways the car had been having some trouble starting, especially during cold starts it would take several times to crank over, i attributed this to a faulty ignition switch, well one day she came home from work, and we were about to go to the store when we got in it wouldnt crank, it wouldnt make any attempt at all to start, so i figured the ignition switch gave out. I went and got the replacement part, replaced it and it did nothing, it was late at night so out of frustration i gave up on it, the next morning i went out and it started right up. Well it continued later that night with the same problem. All the interior lights come on and everything works fine, but there is no attempt to crank, so then i decided to pull the starter and have the starter/solenoid checked. It checked out fine, so then i had the battery checked and it checked out fine. And after re-installing the starter/battery the problem just seemed to go away, well then yesterday she calls and it does the same thing, its been about 2 months since the first occurance, and im puzzled as to what it is. the ignition switch is new, starter and battery checked fine, there doesnt seem to be any clicking at the solenoid switch area, but there is a click in the dash. Ive searched and most everytime it is believed to be the ignition switch as the culprit, but it was replaced, now for some reason after the car sits overnight it starts right up. Well it did, now it wont start at all
So to sum it up, im having a no start/ no crank, intermittently, it will start after sitting over night, heat doesnt appear to be any factor on it. I dont believe it is the neutral safety switch, no codes. Car is an automatic. No click at the solenoid switch when problem is occuring. Battery is at 12.6. All interior lights work, no CEL or anything, car runs great all other times.
Ive done some searching, most all threads with similar problems were the ignition switch, but we did replace that, and now it wont start at anytime, all interior lights come on and everything works but no start at all, just a click at the dash but never any further than that.
When you turn the key on, do all the idiot lights on the dash go on and nothing happens? That's what I've been getting for a while now. But if I keep trying, I can get it to start, every time, although it may take 10 or 15 tries. This only happens once in a while--most of the time it fires right up.
I've replaced the starter, the battery, and the ignition switch, and cleaned the battery cable ground contacts. After I replaced the battery, it was fine for a while. Then we were away for a week, and when we came back the problem started again. My guess is that the current is dropping just below the level needed to start, and then comes back up for some reason. (I've also tried shifting into neutral, but it won't always start when I do that, so I don't think it's the neutral safety switch.)
I've tried adding another ground wire to the starter, but that didn't help. The only thing I have left to try is to do a full re-ground (with wires running all over the engine compartment). There are enough threads here suggesting grounding is a problem to make me think that might be it. If it isn't, I'm at a loss...
yeah all the lights come on, and everything works fine in the car, when i try to start it they all stay on, its not as if they are losing power at that point like the battery is dead, i actually just got it to start, i got under the hood and just played with some of the grounds and the connections. and i got back in and it started, i wish i could have pinpointed which one it it was. but at least i have isolated that it isnt a faulty part.
http://forums.maxima.org/showpost.ph...&postcount=751
Took me 45 mins to redo, completely, both power and ground wires on the battery. Maybe 10$.
alright i tracked it down, a wire going from the solenoid into the starter motor is exposed. i can actually make the car start, and not start now lol. So going to try to take care of that. Thanks guys.
There is a sensor in the center console used only by the starting system to tell it when it is in p/n, it get's dirty and nasty and sticks and only requires cleaning.........from what I hear...........
Goobergo, it sounds like you have the same problem. You try things until something works, then you try the same thing the next time and it doesn't. And it doesn't happen often enough to really track it down.
I just pulled both relays that seemed related to the starter this weekend, and shot a bunch of contact cleaner in them. The starter seemed to crank faster, but that could be my imagination. It may be a while before I know if it did any good (or I may find out it didn't the next time I crank it). It that doesn't work, I think I'll have to re-ground everything, although I may try cleaning the neutral safety switch first...
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
