Just got my new valve covers (pic)
Old Sep 30, 2007 | 09:49 AM
SurraTT's Avatar
HR Swap Pioneer
well of course my 02 valve covers leak at the sparkplug tube seals.
so i went to the dealer and picked up some fresh 04 3.5 maxima valve covers
the part numbers for 04 valve covers are:
13264-7Y000
13264-7Y010
i got them for $35 each
compared to the 02 VC for like $130 each!!!!!!
you will need to buy valve cover gaskets also,
13270-EA20A
13270-EA21A
the gaskets where around $8 each
also the new vc comes with a pcv valve so save ur $8, unlike i did order one. so i got a bran new spare now!!!
UPDATE:
Ive had these for a longggg time now, with NO Problems AT ALL!!!!
Here are most of the pics
Old Sep 30, 2007 | 09:56 AM
pbn85's Avatar
are those both front and rear valve covers? I heard its the rear that usually cracks and spits oil out. But for that price you may as well get the front one too...So the 04 one will fit on a 5.5 no problem? take some pics during the install if you can
Old Sep 30, 2007 | 10:06 AM
Teufelhunden's Avatar
i didnt know they fit. let us know how the install goes.
Old Sep 30, 2007 | 11:29 AM
davemac's Avatar
I couldn't understand the difference in $ and couldn't see how the valve cover could be different between 02 - 06. But, I believe the 02 - 03 are aluminum and the 04 - 06 are plastic - but should otherwise fit. I'll stay tuned to see how the replacement goes.
Old Sep 30, 2007 | 11:39 AM
maxspeed96CT's Avatar
The original VQ...
keep us updatd, i think im getting oil in the cylinder on the drivers side , closest to the firewall, i though it was just the gasket, its the entire cover??
Old Sep 30, 2007 | 11:50 AM
davemac's Avatar
If you could replace the spark plug tube grommets separately it would be just gaskets. But, the grommets are built into the valve cover, so ... new valve cover.
Old Sep 30, 2007 | 12:37 PM
The original VQ...
I see, i have been procrastinating on fixing mine for a while now. Keep us updtaed on the fitment and etc...
Old Sep 30, 2007 | 02:25 PM
LA02MAX's Avatar
Nope, both are made of the same grade plastic, and are essentially the same thing.
The only notable difference between the 5th gen and 6th gen valve covers is that the gaskets that surround the spark plug chambers are a bit more rubberized on the 6th gens which allows it to fit snug and not slide up the chamber like ours do (which are made up of a harder, more plastic-like material).
I think the difference in price is due to part availability. They probably don't make the ones that came stock on the 5.5 gens anymore. I'm willing to bet that they just raised the price to rape people because they knew there was a problem, yet they use the same part as the 6th gens when the dealer replaces it. That's nissan for you.
Old Sep 30, 2007 | 04:12 PM
SuperStasiu's Avatar
why not get them powder coated
Old Sep 30, 2007 | 06:59 PM
SoonerFan's Avatar
Cletus
its the same engine
Old Sep 30, 2007 | 08:40 PM
Originally Posted by soonerfan
its the same engine
i know that, i thought they'd make it a lil different so that we HAVE to get 03 valve covers. but i guess not.
Old Sep 30, 2007 | 10:15 PM
danger300z's Avatar
its the same engine
no but its not the same valve cover , the 04-06 have a diffrent shape where the air intake tube goes in.also the valve cover gaskets are no the same. so if you guys replace the valve cover make sure u guys get the matching gasket .
Old Sep 30, 2007 | 10:19 PM
SoonerFan's Avatar
Cletus
the upper half of the engine (where the covers meet) is exactly the same. of course it will fit. you can change the cover...the ENGINE is still the same
Old Oct 1, 2007 | 01:59 AM
DasYears
arent the gaskets built into the valve cover? in which case "get the matching gasket" would be a given?
Old Oct 1, 2007 | 08:10 AM
SurraTT's Avatar
HR Swap Pioneer
i think the main reason the 02 03 vc are soo expensive is that nissan knows that their is a problem so they jack up the price. im going to deeply compare my 02 to the 04 and see if there is any difference
im thinking if there is any difference its not going to matter at all.
only thing is im doing it on saterday. so thats a lil ways away.
i can wait though
Old Oct 1, 2007 | 08:47 AM
LA02MAX's Avatar
Did anybody read my post? There is no physical difference in the 02-03 VCs vs. the 6th gen VCs besides the spark plug gaskets. Everything is the same. The heads are the same, the gasket is the same, (which, BTW is not built into the VC, only the small round gaskets that go around the spark plug chamber are), and it still functions exactly like your stock VC. How it's this hard to comprehend I'll never know.
Old Oct 1, 2007 | 08:48 AM
LA02MAX's Avatar
Yes baking plastic at high temperatures would be a marvel idea.
Old Oct 1, 2007 | 09:04 AM
SoonerFan's Avatar
Cletus
im agreeing...same engine same VC
Old Oct 1, 2007 | 03:16 PM
The original VQ...
hurry up bro, your holding me back on fixing my leak....
I might just cross my fingers and buy the 04 valve covers tomoro and install them saterday too!!
dnt see why they woulnt fit so....
Old Oct 1, 2007 | 03:46 PM
slickrick's Avatar
They do...E55 and I put an 04 cover on my 02 with no issues at all.
Old Oct 1, 2007 | 03:56 PM
boris's Avatar
What is E55?
Old Oct 1, 2007 | 06:50 PM
Soon2bMD's Avatar
What problem will this fix by replacing these?
Old Oct 1, 2007 | 06:54 PM
DasYears
Originally Posted by boris
What is E55?
another member
Old Oct 1, 2007 | 06:58 PM
NmexMAX's Avatar
dot dot dot ...
E55AMG2 = 5th Gen Moderator.
Old Oct 1, 2007 | 09:39 PM
MIKE2K2's Avatar
Custom User Title
I put an 05 cover on mine..... .
FSM tells you to scrape off and put a new dab of silicone on the corner if I recall. Can't remember which one. You'll see it when you pull it off.
Old Oct 1, 2007 | 10:21 PM
Vadim's Avatar
I just put some silicone around the grommets and re-installed mine. haven't leaked since.
Old Oct 2, 2007 | 07:07 AM
ghostrider17's Avatar
TSB??
Anybody know if there is or ever was a TSB for the Valve Covers / Gaskets on a 5.5 gen???
gr
Old May 15, 2008 | 07:29 AM
Gaskets???
I don't remember is this was clearly answered or not:
Does the replacement GASKET come WITH the new (04) valve cover(s)??
thks,
gr
Old May 15, 2008 | 07:41 AM
nlmaxima's Avatar
I think you have to buy the gasket separate but the spark plug tube gaskets are made into the valve cover therefore you have to replace the cover.
Old May 15, 2008 | 10:57 AM
SurraTT's Avatar
HR Swap Pioneer
no gaskets come with the valve covers.
so yes buy the gaskets.
Old May 15, 2008 | 11:02 AM
thanks for clarifying.
gr
Old Oct 26, 2008 | 07:19 AM
SurraTT's Avatar
HR Swap Pioneer
http://i173.photobucket.com/albums/w...0835Medium.jpg
http://i173.photobucket.com/albums/w...0836Medium.jpg
http://i173.photobucket.com/albums/w...0840Medium.jpg
http://i173.photobucket.com/albums/w...0845Medium.jpg
http://i173.photobucket.com/albums/w...0847Medium.jpg
update!!!!
finally adding the pics
hahah better late then never!!
Old Oct 26, 2008 | 07:37 AM
wyche89's Avatar
the front one seems pretty straight forward.. correct me if i'm wrong, but with the front one, you just bolt it off after you take off the engine cover and remove the spark plugs right? and for the rear one, you just take off the IM, take out the spark plugs, and the valve cover just bolts off from there right?
Old Oct 26, 2008 | 07:39 AM
wyche89's Avatar
hmmm...
Old Oct 26, 2008 | 09:35 AM
SurraTT's Avatar
HR Swap Pioneer
front is very easy ,
remove engine conver. remove coils, un attatch harnesses, unbolt vc
rear is , remove intake upper intake system, remove coils, unattatch harnesses, then undolt vc
hmmm...
might work but i would rather just replace the vc's
Old Oct 26, 2008 | 02:57 PM
Scottwax's Avatar
That's Mr. Detail to you
Even the parts guy at Don Davis Nissan in Arlington said whenever I need to replace the valve covers to get the '04 ones. Nice to know there are parts guys who let you know what your options are.
Old Sep 29, 2009 | 02:00 PM
Maury's Avatar
So let me ask this ... if I told you I removed the intake manifold last month to do a tune-up, would you think I could replace the valve covers and gaskets in my driveway with some help? Or is this to big a job for me?
Old Sep 29, 2009 | 02:25 PM
Stormzusmc's Avatar
front one is cake - rear one, is a little more difficult
Old Sep 29, 2009 | 02:35 PM
Maury's Avatar
Maybe I should try just replacing the front one first, and see if I've stopped the leak?
Old Sep 30, 2009 | 05:23 AM
You haven't.
It's still there, waiting for you...
Just resolve yourself that the engine is going to lose oil, keep dumping it in periodically....and you'll sleep better at night.
I look at it, like I'm EXTENDING my OCI's by a few thousand miles -- adding 1.5 qts between changes!!!
gr
**btw - Check your sparkplug TUBES first before you yank the front cover...if it's dry, I'd say leave it alone.
Are you losing any oil at the front of the engine?? WHere the Valve cover and block meet?? If not, also -- leave it alone.
My front VC was fine, but my rear was leaking into the tubes -- very common for us!
