Camber bolts or plates?
My tires are wearing out bad on the edges and they always have since I lowered it on Sprints. I have H&R on there now but they still wear wrong. So, do I need to get camber bolts or camber plates. The guy at Firestone said I need camber bolts. I really don't know the difference. And will this pretty much guarantee that the car can be aligned properly?
pretty much.
Eibach camber bolts (what I have) are like $31 from the group deal
ground control camber plates will be $100-200 more if you can find them... good luck with that
camber plates are better for precise control of camber and ease of adjustment, but they don't make them for maxes any more apart from with coilovers and they're very scarce... so just go with bolts. it's an easy install.
pretty much.
you just yank the upper of the two bolts connecting the spindle to the strut housing and jam the camber bolt in there. tools req'd: jack, 21mm socket, 19 and 18mm sockets and a crescent wrench
Well I have replaced all the bushings,tie-rods ends and I think that is it so maybe something is up with that. I am just trying not to put too much $ into it because it will probably sold the end of the year. But for the time being and the future buyer I want to get the suspension right.
I don't know the specs but I have the lifetime alignment at Firestone.
The front left wears on the outside and the front right wears on the inside.
Also the car has never been wrecked so that shouldn't be an issue.
Thinking of it, what else could be wrong with a suspension that would be causing this problem other that the lack of camber bolts?
I put the sprints on in 2001 and it wasn't until about 2004 until I replaced alot the parts I listed above, after I went thru a set of tires. Before the lowering the alignment was fine. I then put the H&R on about two years ago thinking the odd tires wear would stop but it didn't.
when you lower the car, you change teh geometry of the suspension and steering. When the car is lowered, it changes the alignment.
i.e. EVERY time you change springs or other suspension components you should get teh car re-aligned.
if your alignment is perfect with OEM springs and you switch to lower springs, your alignment WILL be off....
there should be no need for camber adjustments unless you are slammed to the ground, and your camber should be within spec on H&Rs, definitely.
So if that is the obvious you all are speaking of then that's already covered. See, that is what is getting me, I am doing the alignments accordingly but still the bad tire wear. Maybe it's a bad alignment, maybe I need camber bolts even though people don't think you do with H&R, I'm not sure, but I still am stuck trying to get this right.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
@obvious.
Seen it too many times.
