MEVI, JWT feels slow
Just to start off this is based off of butt dynoing....
I have a 95 auto with I/Y/E MEVI and 7200 JWT, and lightweight 15lbs wheels....
In the last couple of days it seems like I am missing some power down low....not the midrange, and it seems to take FOREVER for the gears to go all the way through....
and my 0-60 using a stop watch is in the mid 7s....that doenst make sense to me since that is what the max does stock.....
I replaced the KS last year...also my only codes are p0600 which I cant get rid of, p0720 replaced it and still get it, and p0400 EGR flow malfunction...
any other ideas???? or am I just to damn picky....
edit: dammit...
I think I know what you are going through. The same thing happened to me a couple weeks after I had the JWT ECU.
OBD II scan revealed DTC sensor / something like that. I could totally feel the power loss that this caused. Took the Sensor off, cleaned it off and tested it which revealed it was crapped out.
Replaced it and look at my times now... beautiful. Hope you figure it out.
Lol. Must you always be the azz to point out the obvious? Lol. Seriously, when ever I see a reply with a dumb question that was already answered you're always the first person to point it out. You must get a kick pointing this out cause you do it pretty much ALL THE TIME. Ah well if you have nothing to contribute then :stfu: You got me this time though.
Heh i get the P0600, i figure it has something to do with the JWT ECU. I havent noticed it yet, i still dont have the top end i should, stupid leaking vacuum canister, but mid-low range power seems normal. I think i will check my CPS too.
Do any of you guys with the JWT ECU notice your check engine light intermittently come on and off? Like i got the P0136 but sometimes my CEL comes on and sometimes it doesnt evne come on. Doesnt really bother me, i wish my airbag light stopped coming on too lol..
I have a 97 Maxima with a 96 JWT ECU. No check engine lights which is weird because everyone says that it should throw one. Other than that first incident I haven't had anything else happen with the ECU.
NMex said I needed to datalog....so I did....The first thing I noticed after a couple minute drive was that my IAT was at about 120 degrees and would spike near 130ish.
That was with the IAT just sitting in the engine bay. So I took the filter off and decided to stick the the IAT into the filter and close it back up....My engine was cold when I went back out to play with the OBDII again....This time the IAT was at 89 degrees to start....also after a 40ish min drive I get home and the IAT is only at 105....Throughout the drive It spiked at 113 for about a minute after a LONG WOT run....
I also had the same gawd damn codes as before....
One thing that was weird or If I am just
but on my WOT runs my TPS was only at 90%. Is that all the throttle opens up or huh....
That was with the IAT just sitting in the engine bay. So I took the filter off and decided to stick the the IAT into the filter and close it back up....My engine was cold when I went back out to play with the OBDII again....This time the IAT was at 89 degrees to start....also after a 40ish min drive I get home and the IAT is only at 105....Throughout the drive It spiked at 113 for about a minute after a LONG WOT run....I also had the same gawd damn codes as before....
Even though the FSM states that, whenever my IAT gets unmounted from my filter area (falls down) The car feels horrifically slow, and throttle response is
I will be the 1st to call
on the FSM.
. I will be the 1st to call
on the FSM.
Lowering my IAT did have a pretty significant boost in overall power and throttle response....Also decided to clean the throttle body today...It did help but only slightly....probally since the MEVI is only a couple months old, it is still pretty inside....
litch
123
Jan 4, 2024 07:01 PM
) heh..but its all good.
