WTB 2000-2001 2002? 2003? Headlight Wiring Harness Plugs
Hi There:
I recently acquired a 2000 I30 with the HID oem headlights and harness connectors. Unfortunately, the front end was gone before I got it and I now want to convert the headlights to a more reasonable standard headlight assembly. I tried to find another I30 being parted out with the parts I need, but could not. I am fairly sure the 2000-2001 Maxima is the identical harness since they are basically the same car, so I am looking to find a decent set (L & R) of headlight wiring harness plugs for the STANDARD headlights.
Let me know what you have. If you are parting your car out, all I need is about 6-12 inches of wire and the connectors and I'll be good to go.
You can PM me as well.
Thanks!!
P.s. also, please let me know whether the 2002 or 2003 harnesses are the same as the 2000.
Ted, Chicago
Thanks!!
Ted, Chicago
When you say "standard," do you mean for the halogen or HID headlights? I ask b/c the 00-01 Maxima's have halogen headlights with a H4 plug for hi/low and a 3-wire plug for a single bulb for the turn signal/parking light. I most likely don't have what you're looking for but I may be able to help clarify...
"the 00-01 Maxima's have halogen headlights with a H4 plug for hi/low and a 3-wire plug for a single bulb for the turn signal/parking light"
I was not sure if the 00-01 Maximas were available from the factory with HID headlights, but I need halogen the H4 plug and 3 wire corner light harness sections.
If anyone is parting a car out and has these please let me know.
Thanks!!
Ted, Chicago
Thanks!!
Ted, Chicago
I just rec'd the standard halogen headlights I bought for my I30 and it requires both the H4 and H3 connectors. Not sure which one is low and which is high right now, but if anyone is parting out their car and has these for both sides, please PM me with a quote. I checked at Autozone and few other car part stores, but they did not carry these.
I also need the hood windshield washer nozzles as well.
Thanks!!
Ted, Chicago
(312) 259-9342
Thanks!!
Ted, Chicago
(312) 259-9342
Justin Kroll
Sep 2, 2015 11:06 AM
