A few questions from a newbie....please help!
a few questions, is there anything particular method on how i should put on my courtesey FSTB? also occasionaly when i rev up my engine (and only occ.) it will put out some white smoke, is this bad and what do you think could cause it? and last for anyone who has a transmission cooler are they hard to install and how bad will it affect my heat in winter? (i live in central IL) thanks for everything and sorry for the long post.
Re: A few questions from a newbie....please help!
On the FSTB, be sure to use a good torque wrench, and don't strip the nuts, like I did.
Attach the bar end links to the bar and even them up on either side so that the brace is 'centered' between the mounts, fitting one end link to a mount loosely and then aligning is the easiest way. When your happy its centered tighten the end links. Then tighten the bars locking nuts to the point where they are firm but not 'pushing' or 'pulling' on the bar itself.
This took me longer to write than it does to fit the bar, good luck!
there has been no coolant lost at all it stays filled to the brim, and no overheat either. i will check tho, it may be a coolant leak. whatever it is its sort of embarrasing.....i got my fstb on, and i love it! the max corners SO much better, and stiffens it up a little on the highway. this is the best low cost upgrade i have ever made! thanks for the ideas guys. i let you kow what i find....
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
