Are suspension upgrades too much for our cars?
While I was bleeding my mushy brakes this past weekend, I checked out the suspension on each corner to make sure things were in order. Lo and behold, I discovered a broken passenger side rear sway bar carrier bracket. See pic below. I have Progress sway bar and springs, KYB adjustable shocks, and Racingline endlinks.
My question: Can our car handle the stiff suspension upgrades we have been doing? Thoughts? Opinions?
Street car chassis are designed to flex, so I think there is a point that the stiffness in suspension weakens the chassis and/or damage parts. You also track your car, so that adds more stress to your car than most of the rest of us.
of course upgrades can be too much. there has to be flex somewhere. otherwise the more we tighten it up, the more little and even bigger things will start to give.
when talking to the gearheads at my factory job when mods started popping up for us, they talked about getting cars on rails making them turn on a dime, and staying low and flat as possible. eventually windows would break or other parts due to all the stress.
we have to keep in mind the more we try to imitate race cars, the more we will be replacing failing parts just like they do.
Maybe we just need stronger parts, maybe start searching pro racing part sites...
I'm sure with your car doing Auto-X it makes a bigger difference and maybe you need to see how much preloading your endlinks are doing, just a thought...
Pre-load is probably even more critical when going through the stresses of auto X. I noticed that the broken end of the bracket was rusty, so it didnt just break. I'll try to get the car up on ramps this weekend and examine the preload. Basically, I dont want pre-load.
Like a chain... a suspension is only as strong as its weakest link (part). With the added stresses of dropping, stiffening and roadracing, the parts that are made for everyday driving will break a lot sooner.
Question Deus. If you're such a big racer, why in the world did you choose a 6th gen max? Granted, I love this damn car, but it would have to be nearly at the bottom of the list of any racer's short list.
Kamski
That clamp is just a piece of stamped steel, it could have had a tiny slit in it and with all the excess stress you put on it it tore like a piece of paper, no big deal, every 5000 miles you should normally check the car over
Energy suspension makes generic swaybar bushings, but they don't say what these clamps are made of. The pictures show them to be a gold color, so I am thinking it is not a very strong material, whatever it is... I heard that aluminum is pound for pound the strongest metal out there, so maybe TAZ could look into that?
I used to be more into racing. I even have some of my prior race cars in my garage. This just turned out this way. I didnt think Id be racing the Maxima, but I discovered the great potential of these cars. Third top time of day at a high speed event with 50 cars, in a daily-driven car running against FULL on race cars on slicks isnt too bad, is it?
I wonder how long that bracket was broken. I replaced it this morning ($8) and when I theoretically raced that white Evo, the car stayed sooooooooooo planted in the curves.
To avoid rolling over the edges,pump up the tires. Use shoe polish on the sides as indicators of where the tires are being worn after each run. Keep pumping them up til the wear is not on the sides. It may be 50 psi or more.
Thanks for the tip. I usually run 42 front 38 rear but the truck is a different animal. Is 50 safe for the RSA's? One of the Max's I test drove had a nice big bubble forming on its left front. I still pushed it thru the turns b/c it wasn't mine
What tires do you run in race trim? I want some V710's for my next set but they don't even last a full season. That Racingling FSTB thread has my order finger twitching.
What tires do you run in race trim? I want some V710's for my next set but they don't even last a full season. That Racingling FSTB thread has my order finger twitching.I used to be more into racing. I even have some of my prior race cars in my garage. This just turned out this way. I didnt think Id be racing the Maxima, but I discovered the great potential of these cars. Third top time of day at a high speed event with 50 cars, in a daily-driven car running against FULL on race cars on slicks isnt too bad, is it?
Also, put up Chern's 3 Phase mods in the stickies.
Proving that the 6th gen is
.02
On the way home from work, I was thinking about the C6 ZO6 with a roll-cage that I drove around the lot, and it got me thinking about this thread...
...as
as this sounds...how exactly can a car's "parts" be designed for track only? I mean drrrrrrr, ya it's lower and wider and all that good stuff, but how does the STRENGTH of the parts get "designed?"
Adding coil-overs and such adds better handling, but puts stress on so much other stuff throughout the car. How does this alter from vehicle to vehicle and "why?"
and kind of
the more I think about it
Any engineers? liquidvenom*
...as
as this sounds...how exactly can a car's "parts" be designed for track only? I mean drrrrrrr, ya it's lower and wider and all that good stuff, but how does the STRENGTH of the parts get "designed?"Adding coil-overs and such adds better handling, but puts stress on so much other stuff throughout the car. How does this alter from vehicle to vehicle and "why?"
and kind of
the more I think about itAny engineers? liquidvenom*
...as
and kind of
...as
and kind of
Check out that ZO6 again, and see what else were reinforced; and what category it's prepped for.
Stuff built for track purposes is no different then stuff built for off roading or towing, it's just the breaking point increases, thinker, bigger, heavier is all the really do.
The bracket broke, so if heavier thicker brakets are made will the bolt break instead, this seems like a fluke thing, all the 4th, 5th and now 6th gens with sway bars and 1 broken clamp, I think where good.
Stuff built for track purposes is no different than stuff built for off-roading, or towing. It's just the breaking point increases. Thicker, bigger, and heavier is all that they really do.
The bracket broke, so if heavier, thicker brackets are made, will the bolt break instead? This seems like a fluke incident; all the 4th, 5th, and now 6th gens with sway bars, and 1 broken clamp? I think we're good.
Sounded mean as hell, but there were some weird sounds at idle
K, I know that this wasn't classified as a roll-cage, but I did not want to explain it before
Directly behind the seats, right by the headrests, there was a bar mounted with 2 or 3 points to each side...I highly doubt that it was a RSTB, but ya...that's my n00b explanation
I might be an engineer but I also stayed in a Holiday Inn Express last night.
thought so
