Toyo, Yokohama or Falken?
Old Nov 13, 2007 | 11:44 AM
BigL0U's Avatar
The best bang for your buck would be...?
BF Goodridge G-Force Sport $127.00 ea.
Falken ZE-912 for $80ish ea. (economy line?? - prob wont choose but it was a given offer)
Yokohama H4S for $119 ea.
Toyo Proxies 4 $139 ea.
I currently "limp" on Nitto NT 450s. One tire is warped and another needs to be costantly repatched. PITA!!
So which one would you suggest?
Only gonna have this Max for another year or so ... consider the expenditures.
Lastly, as far as speed rating is concerned how much of a difference is it with H and V ratings? I only drive 80mph at most. Please advise.
Old Nov 13, 2007 | 01:57 PM
99BlackMaxMS's Avatar
I have heard only good things about the Falken ZE-912s and for $80 a pop, thats not a bad deal at all. Next I would have to go with the Proxies 4. If you are only going to have your car for another year, go with the least expensive IMO.
Old Nov 13, 2007 | 05:31 PM
MrDicks95SE's Avatar
Offset Is Everything.
id recommend the Toyo Proxes4. great all around performing tire, although with the slightly higher price tag. if youre on a budget and arent planning on keeping the car that long, then go a little more inexpensive. treadwear ratings on these should be 300+ so by the time you sell it, you should still have a lot of meat left.
i wouldnt be too concerned on speed ratings. unless youre constantly driving at 100+ then dont worry about it.
Old Nov 13, 2007 | 06:33 PM
MorpheusZero's Avatar
The ZE-912s aren't bad, but get the higher speed rated ones if you go for them. I have a set and they grip pretty well.
No one really has a negative comment about the Proxes 4 (well ok, get a little noisy at the end of their life plus they wear out a tad quickly), but I wanted a cheapo A/S tire that would last me a long time.
Old Nov 13, 2007 | 07:13 PM
merlin2375's Avatar
just to throw another 2 cents in. I've run H4S on one car and V4S on the maxima. Had good experience with them. They are excellent in dry, very good in wet, and pretty good in the snow.
Your profile doesn't say anything about where you live or what kind of maxima you have...but yokos are a good deal
Old Nov 13, 2007 | 09:28 PM
pbn85's Avatar
I had proxes 4 on my 6th gen 18s that I recently sold. I drove them in a rain and they literally cut through the water on the ground. I wish I kept them long enough to see how they are in the winter. My only grudge with them is the soft sidewalls...other than that, GREAT tires. Im getting them or the 912s for my 17s before the snow hits hard. Im on craptenzas re92s right now
Old Nov 15, 2007 | 08:43 AM
BigL0U's Avatar
Dang... i chose what no one mentioned yet before i saw the replies ... G-force Sport since they didnt charge me tax. Is there anything i should worry about with G-Force Sport? Pros / Cons? Theyre supposed to be a fairly new treadstyle right?
Old Nov 17, 2007 | 08:45 AM
Nopike's Avatar
If you are only planning to keep the car a year I would not be too concerned, I'm sure you will be fine with the G-force Sports.
Old Nov 17, 2007 | 12:46 PM
BigL0U's Avatar
just my luck i get a nailed tire the same week!! brand new rubbers and one already punctured. !#@$%@!! Got it patched so well see how it goes.
Old Dec 5, 2007 | 05:40 AM
mikek78's Avatar
I had the Proxes 4 on my 1993 Mazda 626 V6, they had very good dry grip, ok wet grip, but were horrible in snow/ice, IMHO they are not a true all season tire, almost like a summer tire, only a Summer tire wears a bit quicker and has better grip in the dry/wet for the most part. If you plan on getting them and live in a climate where you do get snow/ice and low temperatures, think about a set of winters...in which case you are probably best off getting the Falken's for $80 each. and with the difference (you have some left over for some winters) then again, I don't know where you live and if you will need them...
Old Dec 5, 2007 | 08:50 PM
pbn85's Avatar
really? So many people told me proxes 4 were not bad in the snow..but I believe you. Im so confused b/c I need a set for my 17s now that the snow is coming...
Team STILLEN
Aug 10, 2015 04:29 PM
Jeff2k1GLE
Apr 23, 2001 02:49 PM
RICOiz704
Feb 1, 2001 04:20 PM
