ADDCO Sway bar question
I installed this, and after about 2 months, the top end link tore away from the car (see pic). Did I install it wrong? How can I fix this? This ever happen to anyone?
Re: ADDCO Sway bar question
No it was installed correctly. This is a common problem with the Addco bar. The best you can do to fix it is take it to a body shop and ask if they can weld in a stronger piece of metal to replace the stock stamped steel piece. I had tehm replace it with a piece of angle iron and it hasn't moved since.
Have them do both when you take it in. The extra strain on the other will cause it to break also.
Re: Re: ADDCO Sway bar question
I don't have a picture. Have the guy look at the bracket. Tell him that the sway bar pulled out and you need him to fabricate a stronger bracket. He shouldn't have a problem understanding it once he looks at it. I wouldn't use the term "endlink" since that isn't the part that broke. An endlink is the long bolt at either end of the sway bar that attaches the end to the struts. I would call them sway bar supports or something, endlinks might be confusing him.
Originally posted by UndecidedMax
thats pretty ugly... suspension techniques all the way!
I know of several other guys that have had this problem with addco and ST bars.
This happens a lot
Both sides did it on mine. I had my mech cut off the old brackets and weld new steel (angle iron) peices in thier place. Tell them to turn the welder down or it'll burn a whole in the bottom of the car! Susp. Tech will do this too, break the brackets.
i dont understand, is this just happending in the rear ?
and what is ripping apart?
and why does it rip apart?
and last question, do the sway bars Reduce A LOT of body roll? or is it just minimal?
i would buy them if it will reduce all of most of the body roll of our cars.
what about the front sway bar?
Who has an aftermarket front and rear sway bar that has had the rear rip out? I had attributed mine riping out due to the fact I only upgraded the rear to a firmer bar? I wonder if the front is also upgraded if the problem still occures?
Question:
How's the ride with the Addco compared to stock? My *cough*pu$$y*cough* friends already complain how stiff the stock suspension is.
Originally posted by Bman
Question:
Question:
Yeah, I should've been more clear. Large bumps that affect both rear wheels at the same time (large waves in road, speedbumps) theoretically should behave the same, but any smaller bumps that hit one wheel and not the other (potholes, manhole covers, etc) will feel worse. I was just wondering how much worse. Thoughts from owners?
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
Stagnet04
Sep 14, 2015 11:28 PM
