Freakin bearins are goin bad AGAIN
This will be the third time that my front hub bearings went bad.the first time i did them myself being the first that i undertook a job like that i bought the new bearings. took the inner races out and put them into the old bearing housing.Before anyone gets a chance to say it: boy that was stupid.for the record i have no problem admitting my stupidity. the second time i took them to a local shop had the guy press them out and in.I marked everything just to be safe and sure that everything that was put back together properly.A month late bad bearings again,I got fed up and put the damn thing in the shop.turns out that my hubs where bad.I went out and brought two new hubs. problem solved!?! Not at all. Bearings are bad i hear a humming sound from the right front wheel when everything is turned off and driving the speed limit. I've been using timken bearings. are they good bearings are could something be causing the problem.Second problem instead of starting to threads i thought i squeeze it into one. the ol'girls check engine light came on.I had it scanned it was a code 33 o2 sensor.I ran like crap for two weeks up until today ran like crap this morning,on the way home she was just as smooth as ice. my question is what the hell? im stumped has anyone had this happen to them
My vg hubs went bad (I guess driving too hard) and they would eat up bearing till I swapped in some ve ones. I donno... just my experience. Are you pressing the new ones in? Properly with a press?
he said timken bearings.
as for the o2 sensor, mebe it was covered in soot, and got enough knocked off somehow to
function correctly(see signature)
or it could be a faulty wire problem that has corrected itself for now....
yeah they were pressed out with a hydro press and pressed in with a hydro press.I dont beat on the car at all......well once in awhile gotta be honest.i spend more time trying to keep it clean.its just pissin me off how times i've had these bearings done.Any recomendations on anything or than timken bearings
Timken sells some of the best quality bearings. the brand isn't the problem.
You must replace the HUB AND BEARING AT THE SAME TIME. If you don't, one bad part will ruin the other.
I hope you haven't ruined the new hubs yet with the bad bearing on them. If so, then just go to a junkyard and buy a set of spindles for $35 each from a wrecked car and call it a day. that's usually what I do to get a good hub anyway. way cheaper to buy a junkyard one for $35 and tear it apart (and return it for another one if necessary) than to pay the $135/hub from the dealer.
unfortunately a name means very little these days. the brands are making lines for the big box places that have their name but are crapola.
seriously, since i work on my own car, like other people here, I rely on my own observations as to what needs replacement. I have the org and my dad to help me, but if it isnt gouged or over-worn, or anything, it usually doesn't need to be replaced(depending on what part, of course...)
I replaced both my front bearing with used hub/spindle assemblies from my local junkyard for $25 per side from a wrecked 93 with 100k..
Mileage on the j-yard car is key when buying hubs,stay away from the super high mileage ones,otherwise there is a good chance your going to be replacing bad with almost as bad..Ask me how i know..
I kinda want get the hubs and stuff from the stealership,but money's tight and it being x-mas season and the recent move,I just dont wanna have to replace them anymore.The jy sounds nice,plus i have a parts car to use.but the bad side is that i could only use one cause the driverside was hit pretty hard
im just stumped right now and at a stand still the wife's infiniti took a dump on us(flywheel).i dunno.but thanks for the info
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
