Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
SAFETY FIRST!!!!! Workshop/garage safety tips and advice
Old Dec 9, 2007 | 07:35 PM
irish44j's Avatar
retired moderator
We've all done stupid things and injured ourselves working on cars. It's the nature of the beast. If you're working in your garage, you should always have a few things on-hand or nearby in case of an emergency.
- First aid kit
- Fire extinguisher (preferably dry chemical to extinguish flammable fluids/grease fires)
- Safety glasses or goggles. There is some nasty stuff that comes out of cars that you don't want in your eyes!
- A phone (in or near garage/shop) to call 911 in case you do something really stupid and hurt yourself.
- Clean towel to wipe stuff out of your eyes if you get sprayed.
add your own suggestions....
Old Dec 9, 2007 | 07:42 PM
Greeny's Avatar
¯\(°_o)/¯
I make it a point to never get under on any vehicle unless someone is home..period.
(yes,i had a scare some years ago)
Old Dec 9, 2007 | 07:43 PM
irish44j's Avatar
retired moderator
Always use jack stands!!!!!
Old Dec 9, 2007 | 07:55 PM
Greeny's Avatar
¯\(°_o)/¯
one of my jack stands folded up on me..(3800lb mkIII supra) they were old stands also.(i have new craftsman stands now)
luckily i had enough sense to put my wheels/tires under the car behind the stands..they saved me..
Old Dec 9, 2007 | 08:49 PM
headloss's Avatar
Should be in bed...
earplugs, gloves, and cat-litter or sawdust to soak up spills.
Old Dec 9, 2007 | 08:58 PM
irish44j's Avatar
retired moderator
cool, I guess this section is public now
noob gets first non-mod post!
Old Dec 11, 2007 | 05:54 AM
KRRZ350's Avatar
BIG to the fire extinguisher & safety glasses.
Another thing that they required us to do in school was to always try our hardest to rock a car from 2 opposite corners on any lift or jackstands. The goal is to try your hardest to knock it off. Vehicle damage is far better than death. I practice this every day several times a day and have NEVER had a problem, but if I was to ever have one BIG DEAL, I'd still be alive.
on the kitty litter & cleaning up spills. Also. ALWAYS KEEP A CLEAN WORKSPACE. TOOLS ON THE FLOOR = NO
Old Dec 11, 2007 | 09:32 AM
Divewjason's Avatar
Don't forget to turn on the lights if you are working at night or else you might hurt yourself.
Keep the tools that you are using for the project in a toolbox if you are not using them at the moment.
Have someone come out there and check on you regularly.
Old Dec 11, 2007 | 11:19 AM
KRRZ350's Avatar
Almost forgot this.........
PUT YOUR FEET IN THE CAR!! Don't ever pull a car forward or backwards while hanging halfway out of the car.
Old Dec 11, 2007 | 12:25 PM
merlin2375's Avatar
Take your time jacking up the car, your life depends on it. After you've jacked it up and got the jackstand in place rock the car back and forth to make sure it's stable. If you're doing hard work, check the car is still stable during the project.
Old Dec 11, 2007 | 08:10 PM
speed racer's Avatar
Place something behind the wheels to prevent the car from rolling.
Old Dec 11, 2007 | 08:15 PM
Divewjason's Avatar
Wooden blocks work very well for this.
Old Dec 20, 2007 | 02:15 AM
MrGone's Avatar
Never trust hydraulics
Always do the shake test before getting under a car
If you wear jewelry remove it
Be organized
Practice common sense
Don't assume anything
Old Dec 20, 2007 | 08:02 AM
White Shadow's Avatar
Still chugging along...
Disconnect your battery before working on anything electrical in the car.
Old Jan 26, 2008 | 10:47 PM
spdfreak's Avatar
If the car has been in an accident, disconnect the battery to prevent an electrical fire.
Old Feb 21, 2009 | 07:11 PM
metalheart80s's Avatar
good advices
Old Aug 14, 2010 | 12:16 PM
jlee910's Avatar
make sure your hand brake is pulled up when lifting your car.
Old Jan 14, 2012 | 11:51 AM
Laevateinn's Avatar
When removing balljoints with the knuckle assembly completely removed from the car, using a screw type separator, (http://www.harborfreight.com/3-4-qua...tor-99849.html)
never EVER put your body towards the balljoint where it will pop out. I was lucky this morning that I'm not on its way. It will shoot like a bullet O.o
Old May 17, 2012 | 12:08 AM
PVOH's Avatar
Smile
I like car, also know how to fix them.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
uttadms31
Sep 30, 2015 05:24 AM
