Sponsored by:
Sponsored by: CARiD
3.5 Swap won't stay started
Old Dec 10, 2007 | 06:23 PM
SNOMAX's Avatar
PM me for LCA's!
I finished up my swap and the car does not stay started. It seems to rev fine, but I have to give it gas and keep it above 1500 rpm or it dies. I tried holding the RPM's up for a few mins thinking it needs time to warm up, but it still dies when I let off the gas.
So, here are some details:
2002 Maxima motor in a 97, 3.0 timing equip
3.5 oil pan, 3.5 CPS, spliced in
No IACV, no evap
converted throttle body, 3.0 TPS
Headers, y-pipe, UDP and Stillen Flywheel
Aeromotive FPR--I dont know the Fuel pressure, but I have experimented with cranking it up and it doesnt seem to matter too much, still dies.
Codes are for the IACV and EVAP and oddly, Intake air temp, but no CPS POS or REF codes.
I can start it like stock without any problems.
I've been searching all sorts of thread for about 3 days. Any ideas??
Old Dec 10, 2007 | 08:09 PM
oldngivout's Avatar
Willing to learn
You have a converted throttle body, meaning you modified the 3.5 E-throttle to use a cable? You know that the butterfly must be slightly open to maintain an idle speed. There's a screw on the bottom that will allow this. How's your TPS adjustment? You checked the output signal to the ECM?
Face it, without an IACV or cold start plunger, it's going to be fussy. Sounds like you should double check for a vacuum leak as well.
Old Dec 10, 2007 | 08:27 PM
gtr_rider's Avatar
192.168.1.1
Adjust the set screw on the bottom of the TB and it should stay running on its own until you can fix other issues.
Old Dec 10, 2007 | 09:43 PM
streetzlegend's Avatar
Did you ground the coils, injectors, or w/e is it that needs to be grounded.
Old Dec 11, 2007 | 06:07 PM
SNOMAX's Avatar
PM me for LCA's!
I think GTR got it on this one. It's most likely the adjustment screw--I forgot all about that. I tried to give it a turn and the screw seems frozen. I am going to grind off some flat areas to get some vice grips around it when I get a chance tomorrow. Thanks for the help.
Old Dec 11, 2007 | 07:54 PM
oldngivout's Avatar
Willing to learn
It should be a screw with a locknut surrounding it. Loosen the nut first, I believe it is 8mm.
schmellyfart
Sep 25, 2015 04:47 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
cmpowell86
Aug 10, 2015 12:35 AM
Blackwind
Aug 5, 2015 06:35 PM
