5th gen, Nos for Traction Control
Old Oct 24, 2001 | 08:12 PM
AznWontonboy's Avatar
Out of Curiousity, what happens if your running with the traction control on, and you spray nos and you get wheel spin.... the way the traction control works on the 5th gen (dont know if this applies to the 4th gen or 3rd), shuts off fuel to the cylinders making less power to the wheels, and if the nos is sprayed and only a couple of cylinders are working, will this cause any damage to the cylinder walls/pistons?
Old Oct 24, 2001 | 10:24 PM
BigDogJonx's Avatar
This is an EXCELLENT QUESTION, though I cant answer it for you, but I always though the traction control actually cut power to the wheels from actually cutting power to the engine, did not think it meant shutting the fuel off.
Old Oct 24, 2001 | 10:33 PM
I get bored. Hogan do you know the answer?
Old Oct 25, 2001 | 07:17 PM
*BUMPPPP*
Old Oct 25, 2001 | 07:26 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: 5th gen, Nos for Traction Control
(dont know if this applies to the 4th gen or 3rd[/B][/QUOTE]
4th gen does not have traction control as far as i know.
and that is a darn good question
Old Oct 25, 2001 | 07:31 PM
BigDogJonx's Avatar
Originally posted by AznWontonboy
*BUMPPPP*
Maybe I am retarded......... but what the hell does "BUMP" mean when people like you post that in a thread?
Old Oct 25, 2001 | 07:33 PM
Bumping it so people can see the thread again.
Old Oct 25, 2001 | 08:26 PM
Originally posted by yo_its_ok
TCS retards timing and/or fuel interupt, but who would be silly enuff to go WOT w/ TCS on ?
Esp when runnin N20...
if i am wrong....well bye bye motor ?
-Nitrous is evil
im sure somebody has cruised around 20-30mph and floored it, forgetting the TCS or not thinkin about it because no wheelspin, then spraying it... man that would suck now that I think about it. Thanks Hogan.
Old Oct 25, 2001 | 08:49 PM
hmm...I usually turn off TCS if the weather is dry night or day, 1st thing I do...well TCS and WOT wheel spin should remain rich so it should leave some room for extra oxygen molecule....obviously the engine wouldn't lean out....
-Logical enough ?
yup it is. i still feel bad for the engine
Old Oct 26, 2001 | 12:27 AM
i forget
Old Oct 26, 2001 | 12:47 AM
BriGuyMax's Avatar
having the TCS intervene (fuel cuts to cylinders) while spraying will do about the same thing as hitting the rev-limiter while spraying......BOOM...bye bye engine
Old Oct 26, 2001 | 12:56 AM
mtrai760's Avatar
'Trynna' is not a word
-Nitrous is evil
Evil?
Old Oct 26, 2001 | 01:24 PM
costcowholesale's Avatar
Re: Re: 5th gen, Nos for Traction Control
and that is a darn good question [/B][/QUOTE]
yes they do, mine does (only 99s)
Old Oct 26, 2001 | 02:34 PM
WILLSE's Avatar
how about taking traction control off and eliminating the posibility all together!
Old Oct 26, 2001 | 02:36 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
correct, that's what iwas thinking too.
Old Oct 26, 2001 | 03:39 PM
Thanks for the replys.
Old Oct 26, 2001 | 03:44 PM
nvmymax2's Avatar
UUMMMM!!!!!!
Well first I don't have a traction control on my 5th gen, so I guess it doesn't really matter for my car. And also if you hit the rev limiter while spraying the engine will not go boom, but your ecu will throw itself into a safety mode. All you have to do is turn the car off and then restart it. Believe me on this one I know first hand!OOPS!
Old Oct 26, 2001 | 04:03 PM
mtrai760's Avatar
Re: UUMMMM!!!!!!
You got lucky. IF you have everything set up right, then your window switch should cut off your NOS before you hit the Rev limiter, or, if you don't have one, then the fpss should cut off the NOS when your fuel pressure drops. But if you don't have either one, or they or not set up correctly, and you spray a shot of NOS through the rev limiter, expect to have some kind of damage to your engine. You may get lucky once, maybe even twice, but eventually your going to bend a valve or worse...
Old Oct 27, 2001 | 05:19 AM
very lucky boy you are. i would have liked to see that happen.
MAXSE5SPD
Sep 17, 2022 04:00 AM
stevesmax
Dec 17, 2020 11:57 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Lowered_a33
Sep 1, 2015 07:49 PM
