Changing a brake light 2004 Maxima?
Old Dec 14, 2007 | 10:23 AM
bushpilotmexico's Avatar
I looked in the sticky under specs and info to see if someone could tell me how to change a brake light bulb. Some threads led no where and I couldn't find any info?
Any help would be appreciated....I assume you change it from the inside of the truck but the liner has to be removed?
Old Dec 14, 2007 | 10:38 AM
redls1's Avatar
MAXIN' ON
If its anything like the 07 you pull back the liner( take the plastic push plugs out), loosen the 3 nuts and pull the whole light out to get at the bulbs I believe.
Old Dec 14, 2007 | 10:40 AM
IHAVEA2KMAXIMA's Avatar
I thought owner's manuels have like a DYI section that includes changing the bulbs and stuff.
Old Dec 14, 2007 | 02:55 PM
forced347's Avatar
Yes, you remove the liner in the trunk and remove the screws (not sure if its 3 though). 5 minute fix.
Old Dec 14, 2007 | 04:13 PM
92 Max's Avatar
It's a very user hostile design. See my post from a few months ago (9-15-2007).
http://forums.maxima.org/showthread.php?t=536302
Old Dec 14, 2007 | 04:30 PM
Silverfox's Avatar
be very carefull when removing the brake light. The surrounding painted parts are plastic and will brake or crack if you are not cautious. Id suggest using a pannel pop, but that may not work for everyone if you are not sure how much pressure you use. upgrade your reverse bulbs while you are at it (BRIGHTER) try V-leds on ebay to get them.
Old Dec 15, 2007 | 01:31 AM
jsmithsole's Avatar
*moderator*
FTR follow the instructions at the top of the stickies, and then they will work.
with the entire forum revamp, to see old links: change "showthread" to "oldthread" in your address bar after clicking the link.
I have a "how to" in there with pics...
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
Samedi
Aug 13, 2015 04:05 PM
Flores94
Aug 11, 2015 12:53 PM
RealityCheck
Aug 5, 2015 06:18 AM
