Why does my IACV Constantly Click? -Video!
Old Dec 14, 2007 | 01:14 PM
RedfoxXx's Avatar
Im converting back to to stock from DEK and my car will not idle after I start it up. The Idle Air Control Valve will constantly click on and off.
I have tried another IACV and it still clicks.
I have traced the wiring all the way back to the ECU and it checks out okay.
I have checked all the fuses and relays.
No check engine lights, codes read nothing is wrong.
Does anyone else have any ideas? I am at a stand still and I want to drive the car into a wall.
Here is a video of what it is doing.
Old Dec 14, 2007 | 04:19 PM
black_maxed95's Avatar
mine clicks sometimes too, idk what it is either
Old Dec 14, 2007 | 04:40 PM
KRRZ350's Avatar
Make sure that your ECU screw isn't in self diag mode, that will do it.
Old Dec 14, 2007 | 04:50 PM
chillin014's Avatar
i think its tryna throw down a beat.
im feelin it....pnut butter jelly....pnut butter jelly with a baseball bat
Old Dec 14, 2007 | 05:00 PM
KRRZ350's Avatar
Wow, I didn't watch the video until now. Still check ECU mode. But care to elaborate on what's up with the wiring
Old Dec 14, 2007 | 05:14 PM
vqmaxman's Avatar
I think your car is trying to make a vicious beat or it's a ticking time bomb waiting to go off. or it's trying to talk to you.
I would check the ECU or the wiring for some extra voltage.
Old Dec 14, 2007 | 06:04 PM
96blkonblkse's Avatar
You know mine does the same thing. IT is also stalling on cold start up..where talking like negative temperatures, like -3 to -10. The revs shoot up to 1500 then drop and stalls. The idles kinda lopey in the cold only when its been sitting over night. I wonder if that has anything to do with it?
I never noticed it before, i thought it was my IACV but i was never too sure where the exact noise was coming from.
Old Dec 14, 2007 | 07:05 PM
96sleepergle's Avatar
also make sure you have the proper idle speed 650 - 700 rpm with the car in neutral tps sensor harness off adjust it if needed if its to high it will cause the stepper motor to work hard (clicking) noise
Old Dec 14, 2007 | 09:17 PM
slow97maxima's Avatar
member
Old Dec 14, 2007 | 09:32 PM
RedfoxXx's Avatar
ok so the ECU was in diagnose mode, that fixed the clicking THANKS!
I cleared the computer but it still doesn’t stay running,
it is a real confident start, but it dies unless I give it gas, any thoughts?
Old Dec 14, 2007 | 09:36 PM
vqmaxman's Avatar
Try the good old disconnet the battery for at least one day that should work.
unless you tryed to fiddle around with the screw.
Old Dec 15, 2007 | 07:52 AM
RedfoxXx's Avatar
can anyone get me a good pic/ description of where everything on the VAC galley is should go
do both the nubs under the 95 TB go some were or was one capped? Where do they go? Thx
Old Dec 15, 2007 | 08:39 AM
Achmed's Avatar
Bigsix3
Sounds like you've got some wires crossed. Check out your birdsnest and make sure they're connected properly.
Old Dec 15, 2007 | 09:08 AM
RedfoxXx's Avatar
thanks everyone its working,
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
junito1
Sep 23, 2015 12:14 PM
bumpypickle
Sep 20, 2015 08:22 AM
bennuss
Sep 11, 2015 05:55 AM
