FULL DEK PART OUT w/ 00VI stuff
Rear valve cover $25 - SOLD
(3) rear coil packs $40 - SOLD
2000 TB W/ IACV w/ harness $50 - SOLD
Upper manifold $85 (VIAS has been JBweld )
lower manifold (in poor shape holes are stripped) $20 (Swirl valves removed ) -SOLD
injectors & rails, injector harness' $35
EGR tube $30
(SHIPPING IS EXTRA)
hardware is all here just tell me what you need
bolts, head to UIM Brackets, there is even a WOT switch mounted on the TB for you!
$300 + shipping for all 00VI stuff
if there is enough interest I can part out
2000 maximal cams $35 + shipping
2000 maximal heads $45 a pop + shipping - SOLD
3 front coils work with 95-01 maxima $25 - SOLD
Front valve cover $10 + shipping
Brand new Front valve cover gasket set (with grommets and spark plug tubes seals) – 10$ + shipping
99 maxima Lower intake manifold w/ swirl valves - $10 + shipping
4th gen IACV w/ fast idle valves and block - 15$ + Shipping
Everything else that comes with an engine is up for grabs, make me an offer on anything sensors, blots brackets, crank shaft, rods, timing chain stuff, exhaust manifolds, clips of cut harness, ANYTHING
Lo balers welcome
Parts are in New Tampa Florida if you want to pick anything up
EGR tube $30
(SHIPPING IS EXTRA)
Lo balers welcome
MAXSE5SPD
Sep 17, 2022 04:00 AM
Maximeltman
Aug 31, 2015 01:01 PM
