Can't remove CV bolt
Old Dec 18, 2007 | 03:55 PM
Olezhka's Avatar
Can't remove CV NUT
I tried for about 2 hours already.
I tried the motorvate.ca write-up way and broke 2 screw drivers.
Is there anything else I can try?
Old Dec 18, 2007 | 03:58 PM
TunerMaxima3000's Avatar
CV bolt? Am I ignorant or am I missing something?
Old Dec 18, 2007 | 04:12 PM
Olezhka's Avatar
LOL I'm sorry I meant CV NUT
Old Dec 18, 2007 | 04:19 PM
soseihin's Avatar
I think you mean the "wheel hub retaining nut". Yeah, I couldn't get it off either. Not even with a cheater bar and a +200lb friend. I'd find a someone with an impact gun.
Old Dec 18, 2007 | 04:23 PM
Olezhka's Avatar
F*ck I already drained the tranny and I need the car tomorrow.
Is it just a regular nut or is it threaded backwards?
Old Dec 18, 2007 | 04:24 PM
Olezhka's Avatar
I'm using a breaker bar and a jack. Nothing, it won't move at all.
Old Dec 18, 2007 | 04:32 PM
Dark_man_x's Avatar
did you try tightening it a little to break it loose? this solved my problem when i was taking off my fill plug on the tranny. if not. find an impact gun and a use allot of pb blaster or something.
Old Dec 18, 2007 | 05:23 PM
ok,
1. put the socket on it, just the socket, and give it a good whack with a hammer (with the wheel in the air.)
2. then drop the wheel back on the ground, and you WILL need at least 4' of leverage. if that means you need a pipe, etc, then get it.
It will come free, you just need more leverage.
It's more effective however if for step 2. you can keep the wheel in the air (assuming you can apply the brakes ie. calipers NOT removed) and you have someone handy to hold the brakes on while you're trying to break the nut free.
and no, both axel ends are a right hand thread (standard)
Old Dec 18, 2007 | 05:26 PM
eclypsecl's Avatar
I was going to say, if you had tranny fluid still in there...turn the car on, put the breaker bar towards the floor at such an angle that when you put it in gear the car wheels turn and you break the bolt off.. another way is to add a scisor jack stand under the wrench..as it goes higher it will push that bolt off ( have to turn the wheel in the direction facing outwards for room.. Hopefully. Good luck.
Old Dec 18, 2007 | 05:34 PM
antilley's Avatar
ok,
This method worked for me as well .... PB and breaker bar was all i needed..... but I weigh close to 3 bills
Old Dec 18, 2007 | 07:55 PM
SNOMAX's Avatar
PM me for LCA's!
It's best to try and break the nut free on the ground, then jack up the car to finish removing the nut. You could also try heating the nut up. Just be careful of the brake lines and rubber bits near the hub.
Old Dec 18, 2007 | 08:49 PM
MaxGordon7's Avatar
I just put a basic 16 inch breaker bar and jump on the bar, done it on 3 different cars. Have to do it with the wheel on the ground. Done it on 3 maximas, GTP and a blazer. Never hit the paint but i could see that happening.
Old Dec 18, 2007 | 09:16 PM
A33 VQ30DEK's Avatar
impact gun FTW!
Old Dec 18, 2007 | 10:44 PM
gen4maxima536's Avatar
i just used an impact wrench. didn't bother trying to use a breaker bar.
Old Dec 25, 2007 | 09:19 PM
maxud's Avatar
Here is what I did:
1. Take off the wheel (in my case Alloy)
2. Take off the cotter pin and the protective piece.
3. Put your spare wheel on
4. Lower the jack, so the spare wheel is on the ground
5. Use 16" 1/2 breaker bar plus a pipe over it as a leverage.
6. If the spare spins, lower the jack a little.
This worked like a charm today. I used some left over shelving pipe (thin walls). I weigh 135lbs and dont have an impact gun
Max
Old Dec 25, 2007 | 10:06 PM
slow97maxima's Avatar
member
Originally Posted by maxud
Here is what I did:
Max
word - except i didnt have a breaker bar and though it would be a good idea to use a torque wrench? (dont do that ). BUT the cv nuts were cake compared to the ****ing crankshaft pulley bolt which needed like 189 feet of leverage
litch
123
Jan 4, 2024 07:01 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
