Need Mass Inspection-HELP!!
As the tile indicates, I need an inspection in Massachusetts. My crankshaft POS is not reading my aluminum flywheel (magnetic sensor does not work with aluminum, something i a.)never thought about and b.)never heard anything about on the forum). So, after riding around since August with the "R-acing" sticker, i am tired of getting pulled over. I am either going to replace the flywheel with a JWT because they have steel teeth and spend $500 and roughly 4 hours doing it or hopefully someone can help me getting an inspection sticker and i will reward them handsomely. Thank you.
There is absolutely no way of getting around the OBD-II compliance testing in MA. Did you swap the trigger wheel over, and is it made of steel? It sounds like you didn't swap the trigger wheel over, which would make me clueless as to how your car runs...
If his CPS is not picking up signal then im kinda confused on how it runs, unless its just the reference sensor?
Are you sure its not an issue with the actual sensor, if its a unorthodox flywheel i cant imagine it being a problem unless you forgot to swap the wheel over, in which case im not sure how your car is even driveable lol
TallTom
57
Oct 14, 2025 05:16 PM
cash94
Aug 27, 2015 08:09 AM
