Anybody tried heated mirrors?
Those mirrors I see on Ebay; heated power mirrors such as:
http://cgi.ebay.com/ebaymotors/MIRRO...QQcmdZViewItem
Just curious because I was driving the other night and the side mirrors were wet/foggy the whole time.
don't buy from this seller, i had a hard time returning a part i got from them and those mirrors are crap. i know some 1 with a 96 that said they looked gimp and did'nt fit right. just thought i let you know, get em used on e-bay or a junkyard. you'd be better off.
heated mirrors have an extra connector that connect to part of the harness inside the door. If your Car doesnt have heated seats it wont have that connector inside the door. You could get clever with wiring something up, but minus that its not as easy as just getting a heated mirror and installing it.
its automatic. if its that cold outside, after you first start your car up and are driving, look at the mirror you'll probably see a rectangle that is clear (or more melted than the rest) you know then its working.
or you should be able to touch it and feel its warm. ( i think it kicks in on cold days, or there is a way for it to know its cold enough outside to heat the mirrors)
i saw you get the pwoer-folding heater mirrors since you are in the mood to upgrade. other than that, heated mirrors are simple to wire even if you have no harness. tap into your rear defroster for the remote lead to a relay.
ps: heated mirrors are usually accompanied by heated seats.
hmmm if thats the case then the defroster button would turn on the heated mirrors.... learn something new everyday
I would stick to buying an OEM mirror I noticed that when I bought a cheap unit the mirror would shake going over bumps on the road and when I had the music up loud. It's no where near as bad with the OEM one I replaced it with but it still does it a little bit. The heated part works fine I just found it annoying.
My SE don't have heated mirrors either. How much is the OEM ones?
(totally unrelated question. why can't I start new thread? It tell me I have no permission. I PM-d few moderators, but no answer. someone help?!)
the power-folding heated mirrors i was referring to are OEM. for US heated mirrors, you can prob get them for $50 each. less if the color shell is cracked (you would be putting your shells on it anyhow).
I haven't read the owner's manual in a while but I do believe it addresses the heated mirrors. I think they come on with the defog button. They may come on just whenever you have the heat on but I think it's only with the defog.
I sold a set of black 4th gen heated OEM mirrors for $100 shipped iirc. You can tell the difference because the heated usually have two wires coming off the mirror, and the non heated ones usually only have one.
But here is my question, were all drivers side mirrors, regardless of what package you had, heated? Because a GXE that I just parted out had 2 wires coming from the drivers side mirror and only one coming from the pass. side mirror. P.S. this car had 0 options.
^ may have been a previous repair, and they just ordered a heated mirror by mistake and went ahead with a repair,
cmon i dont think nissan was drunk when they designed that GXE with one heated mirror - this is not russia dude hehelol
ok, i have a 95 gle that has all the options including heated seats, but when i put my rear def on, i never noticed them heating up. would that have been an option you;d have to pay for???
if there is no frost or anything you wont see the mirrors heating up. Or maybe they were removed at some point. Touch them after a few min of being on and see if they are warm (in the middle)
question on the heated mirrors, kinda unrelated, but is it possible/cost effective to replace the element in the OE heated mirrors? my r/s is burnt out.
And yeah they are activated by the rear def. button stock.
You can check if you have a working heated mirror also by wiping it with a wet cloth an pressing the defrosted button, if it is working fine then the water will dry up and dissapear leaving a stain
thats what happens in the rain (i love using heated mirrors in the rain, cause it clears up the mirror and i can see)
tarun900
19
Dec 20, 2021 06:57 PM
flu2000
Sep 8, 2015 02:23 PM
my car came with them stock
