Largest tire on 17" rim (PICS PLEASE!)
Old Jan 17, 2008 | 09:25 PM
SKarpenz's Avatar
I'm starting to browse wheels for the maxima and I think I want a set of 17's so I can still run some substantial rubber. My question is this: On a standard 17x7" or 17x8" 35-40 offset rim, what is the biggest tire (tallest and widest) I can run without rubbing/minimal contact with body/suspension parts? If anyone can post pics of their setup that would be excellent. I'm probably gonna be on S-Tech springs as well.
I'd like to see pics of all 17" wheels on lowered maximas, please post specs as well (wheel size/tire brand and make/tire size/offset)
Old Jan 18, 2008 | 03:59 PM
hacim105's Avatar
I don't have any pics for you. But first, why would you want a taller tire? That makes your speedometer read incorrectly.
IIRC a 17x8 wheel on our car should not have a tire bigger than 235/45/17 tire. That doesn't mean you can't get more but it is encouraged.
17x7 shouldn't go more than 225/45/17. again that doesn't mean you can't but it is not encouraged.
Old Jan 18, 2008 | 10:19 PM
SKarpenz's Avatar
I like meatier tires. The speedo thing doesnt bother me so much, but I just like meatier tires on bigger wheels.
Old Jan 18, 2008 | 11:31 PM
SKarpenz's Avatar
Could I put a 235 45 17 on a 17x7" wheel?
Old Jan 18, 2008 | 11:40 PM
WhiteMaxima9600's Avatar
Well mines the factory size 225/50/17 for the 03 se wheels. I believe these tires are ventus hrII (they suck) btw.
here's one more......
Old Jan 19, 2008 | 12:05 AM
SKarpenz's Avatar
Does it rub or anything? I like the way that looks. You think I could squeeze a 235 on a 7" wide wheel? 235 50 17
Old Jan 19, 2008 | 12:08 AM
aznprid972's Avatar
I'm running that setup right now with no problems. As what others have already stated, you can do it but would encourage otherwise.
If I remembered correctly, the 235/45/17 was very close to RPM difference to our stock setup. 225/50/17 was off by more.
Old Jan 19, 2008 | 11:58 AM
MrDicks95SE's Avatar
Offset Is Everything.
POST IN THE WHEEL/TIRE FORUM.
stick with factory OE specs. car will be running at an efficient rate that way.
Old Jan 19, 2008 | 12:16 PM
SKarpenz's Avatar
Guys, the difference b/w the 225 45 17 and the 235 45 17 is the width (of course) and less than 1/2" height. The 235/45/17 is like 25.4" tall and the 225/45/17 is 25." Is this really gonna make a big difference in the "efficient rate" my car runs at? The factory 215/60/15 is 25.2" tall. Something to think about. I am gonna run 235/45/17 if I can get them on the wheels, thats my only concern.
I got those numbers from using the same brand and model tire for all three sizes, and using the same manufacturer's specs on width and height.
Old Jan 19, 2008 | 12:27 PM
wuzzy's Avatar
my 17s are 35 offset with 235/45/17 tires
Old Jan 19, 2008 | 12:28 PM
SKarpenz's Avatar
17x7's?
Old Jan 19, 2008 | 01:44 PM
max95q's Avatar
235/45/17's here too on 17x7's with a 40 offset. The shop may try to steer you against it because its " not recommended because it could rub" But they are just trying to cover their butts. I have 235/45's on my 17x7's and no rubbing. I have the Tokico Illumina suspension kit.
Old Jan 19, 2008 | 04:33 PM
MorpheusZero's Avatar
245/45R17 on a 17x8.
Old Jan 19, 2008 | 10:50 PM
No rubbing here at all, Iam pretty sure u could go with that setup with no problems.
Old Jan 21, 2008 | 06:38 PM
S13ORLANDO's Avatar
Hey,
There is a guy parting out new 275/40/17's very cheap.I mean less than what one retails for. This is a real "fire sale".i know the guy is legit and they're not "hot".
Will they fit on my 5th gen 2002 Maxima? It doesn't sound like it would fit? Wont fit the stock SE wheels right?
Bob
Old Jan 21, 2008 | 06:44 PM
SKarpenz's Avatar
275's are hella wide bro. I seriously don't think they'll fit stock wheels on your 5th gen.
Old Jan 21, 2008 | 07:01 PM
S13ORLANDO's Avatar
275/40/17 on 5th Gen Maxima?
Me either..just hard to pass up new tires for $30 a piece.maybe I can buy and trade them for something else?Dammit man,?If only they were 235/40/17! I always end up finding great deals on Crap I dont need.
thanks
Bob
Old Jan 21, 2008 | 07:06 PM
Fr33way™'s Avatar
Wild for Width
Originally Posted by S13ORLANDO
Hey,
Bob
No. Based on your post you need to pass on these.
Old Jan 21, 2008 | 09:18 PM
S13ORLANDO's Avatar
Yeah...maybe get two for my S13..?
Old Jan 21, 2008 | 09:50 PM
Fr33way™'s Avatar
Wild for Width
Crazy me, I thought this was Maxima related. For that price I would flip them unless you have drag plans with your S13.
Old Jan 22, 2008 | 05:30 PM
z32drifter's Avatar
Hey,
Bob
I like 275s I've run them on the Maxima and use them on my Z32. You can't run them on stock wheels 9" min size. I could be a player in cheap 275s
275 race tires
255 front and 275 rear staggered setup.
Old Jan 23, 2008 | 08:13 AM
ROCKART's Avatar
wants an I35
yea 235-45-17 is what tirerack recommends for a 17x7 wheel
but i have a feeling thats because the 235-45-17 tire is far more common, and thus cheaper to get, than the random size of 215-50-17
i actually just bought 4 '04 maxima SL alloys that are 17x7
i was deciding which way to go as far as tires....
my two choices are:
235-45-17 (speedo offset of %0.67)
or
215-50-17
(speedo offset of %0.12)
my first instinct is to go with the 215-50-17 simply because of the sidewall height. the roads here are bad, plus there are lots of traintracks.
the downside to these is the width - i want wider tires a) cuz they look better and b) cuz u get better traction (more surface area = better grip)
plus, these are random weird sized tires, so if i ever got wider rims i would have to get new tires as well....
so the 235-45-17s, obviously are going to be too thin for my liking. other than that, and the perks of a wider tire, is that ill be able to swap them off if i were ever to get wider rims down the road (17x7.5, 17x8, etc.)
plus i think the 235s are goign to LOOK too wide for a 7 inch wide wheel. i got 225s on there now and they hang off the sides a good amount...i think 235 would be over the top
i dunno tho, all input appreciated
Old Jan 23, 2008 | 11:00 AM
Fr33way™'s Avatar
Wild for Width
Are you planning on a drop? 235/50 is an option if you are not slamming. Also what happened to 225 sizes? 215 is stock width for the SE....
Old Jan 23, 2008 | 11:06 AM
ROCKART's Avatar
wants an I35
well the 215-50-17 and the 235-45-17 are the two closest to stock diameter for me...
225-50-17 would be a 1.4% speed diff (too slow) with a .36 inch larger difference in overall diameter
225-45-17 would be a 2.05% speed diff (too fast) with a .52 inch smaller difference in diameter
Old Jan 23, 2008 | 03:37 PM
Fr33way™'s Avatar
Wild for Width
On a car with traction control like the 350Z or something similar I might stress more on overall diameter but fit is more important to me. Also, different tires of the same diameter can vary in total outer diameter and revs/mile so those small differences could be even smaller.
Old Jan 23, 2008 | 06:18 PM
Dave H.'s Avatar
What tire size are you putting in the stock size on the tire calculators?
On miata.net tire calc.:
Using 215/55r16 as stock, that makes 235/45r17 only off by 1%, 60mph=60mph.
Using 215/60r15 as stock, that makes 235/45r17 only off by .7%, 60mph=60.4mph.
Using 205/65r15 as stock, that makes 235/45r17 only off by .6%, 60mph=59.6mph.
You'll actually have a bigger sidewall, .2 inch, if you use 235/45 as opposed to 225/45.
Sidewall size is the same (4.2inches) on 215/50 and 235/45.
max95q is using 235/45r17 on 17x7 wheels and it looks great to me. I plan on doing the same thing.
Anyway, hope that helps some.
David
Old Jan 23, 2008 | 08:08 PM
Fast1one's Avatar
Seriously, I could care less as well....
Old Jan 23, 2008 | 11:36 PM
thatmaximaguy97's Avatar
Nice wheels...love the offset
Old Jan 24, 2008 | 09:01 AM
ROCKART's Avatar
wants an I35
my stock size is 205-55-16
Old Jan 24, 2008 | 12:15 PM
Fr33way™'s Avatar
Wild for Width
Personally I think 225/50-17 has the right mix of everything you want. Rule of thumb is within 3% of speedo anyway. Do you really cruise right at 55 or whatever the posted limit is? In any part of the country I have been in that gets you rear-ended.
Old Jan 24, 2008 | 12:25 PM
ROCKART's Avatar
wants an I35
205-65-15 typo
Old Jan 24, 2008 | 08:57 PM
Dave H.'s Avatar
ROCKART - from reading other posts, it sounds like you may not even be keeping these wheels.
Good luck!
spazma7ik
Jan 12, 2017 09:38 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
0m3nc0w
Sep 11, 2015 05:21 PM
adamgalazka
Sep 8, 2015 01:27 PM
