Chime in About My Tire Choice
Old Feb 3, 2008 | 09:01 PM
maxitech's Avatar
Alright, once the snow melts the Maxima needs a new set of meats...Its 2K3 SE 17's currently have 225/50 rubber on them in the form of Hankook HR Ventus II tires. They have been very good to me and I currently plan to replace them with the exact same thing.
So my requirements are: summer performance-oriented tires, 225/50 size, good dry and wet performance, and try to limit them to $120 a piece. For reference, I paid $105-110 for my current tires at a shop, although I found them online for $86 a piece...And yes, I know, it will cost a few bucks to have them mounted and balanced. Got a tire I should check out, let's hear it...
Old Feb 3, 2008 | 11:04 PM
clickclock987's Avatar
If you want to buy new tires, I find a copoun for Tires on Sale, it may save you some money.
http://dealstudio.com/searchdeals.ph...d=80501&ru=283
Hope it helps.
Old Feb 5, 2008 | 05:13 PM
maxitech's Avatar
OK, I see starting this thread was worth my time...
Old Feb 5, 2008 | 05:56 PM
z32drifter's Avatar
I'd take a look at the Kumho SPT and the BFG G-force sport, the Falken 912s might be worth a look. The G-force sports would be my pick for pure performance.
Old Feb 5, 2008 | 05:58 PM
WhiteMaxima9600's Avatar
I had those same tires on my 03 se rims. Now have General Exclaim UHP 225/50/17. Go to tirerack.com. Got them for $89 a piece and shipped to me in 2days. They have a pretty aggresive tread and are worth checking out if you want a decent summer tire.
Good Luck
Old Feb 5, 2008 | 11:25 PM
maxitech's Avatar
Hmm...all good choices. Any additional thoughts on those different brands? A couple are $10 more each. Not a huge deal, but 40 bucks nonetheless.
Old Feb 11, 2008 | 07:56 PM
maxitech's Avatar
Good Luck
How would you compare the two brands?
Also, judging on nothing but looking at the tires online, I have to say I like the Kumho's...The only problem is they don't make them in 225/50R17, only 225/45...
Old Feb 14, 2008 | 05:54 PM
boondoxmax's Avatar
Potenza RE960AS Pole Position best tires I've owned. You'd love em. Quiet, very grippy, and stiff sidewalls.............
Old Feb 15, 2008 | 01:44 AM
IHAVEA2KMAXIMA's Avatar
My kumho SPT is quite grippy and the pretty looking treads do channel water out very effectively. And I must say I no longer fear the rain now Noise level is quite okay IMO and treadwear is excellent.
But like you said... they dont come in 225/50.
Old Feb 15, 2008 | 07:39 AM
ROCKART's Avatar
wants an I35
i cant say from experience, but virutally every review of GENERAL EXCLAIM UHP tires is glowing. all over the internet they are regarded as one of the best bang-for-your-buck tires available.
they are rougly 80-90 a piece, depending on size.
Old Mar 2, 2008 | 01:48 PM
maxitech's Avatar
Tire rack now has them in that size! I'm definitely leaning towards the Kumhos right now.
Old Mar 2, 2008 | 01:50 PM
maxitech's Avatar
They look like good tires, but the price is a little steep ($171 each).
Old Mar 2, 2008 | 04:17 PM
irish44j's Avatar
retired moderator
Toyo Proxes4 if you want a tire that's good in the rain and dry....
Old Mar 2, 2008 | 07:15 PM
Fast1one's Avatar
x2
I have had both the Proxes4 and the SPTs currently...I love them both, but I think the Proxes has the edge in the rain...very close though, can't go wrong with either for the money...
Only reason why I didn't have the Proxes now was because I got the SPTs in 245/40/18 for 350
Old Mar 4, 2008 | 04:45 PM
boondoxmax's Avatar
I paid 148.00 ea from the tire rack for mine.....If you check the reviews you'll see how much praise these tires receive. I couldn't believe a tire could be this quiet, this grippy in wet and pretty good in snow, yet have a nice stiff sidewall...........I'd buy another set in a minute even at 171.00 ea. Only dislike is they don't look very aggressive
Old Mar 5, 2008 | 03:18 PM
maxitech's Avatar
Too much coin for an unemployed college student. Plus, I don't need them to go thru snow.
Old Mar 5, 2008 | 03:55 PM
MrDicks95SE's Avatar
Offset Is Everything.
i bought Potenza RE950 from Costco for my 15's a while back. not bad as far as grip and wear are concerned. im still rollin on em despite alignment wear.
Old Mar 5, 2008 | 04:38 PM
Greeny's Avatar
¯\(°_o)/¯
I just put a set of dunlop signatures on a few months ago, so far i am very happy with them..
http://www.tirerack.com/tires/tires....num=25WR7SPSIG
Old Mar 5, 2008 | 10:29 PM
Pearl93VE's Avatar
I can has?
For specifically a summer tire (all year in Florida ) I absolutely LOVE my new tires.
Bridgestone Potenza S-03 Pole Positions
http://www.tirerack.com/tires/tires....+Pole+Position
Pro's:
GREAT Dry performance and awesome wet too... I have yet to lose traction braking or hydroplane.
The sidewalls are ridiculously stiff so I haven't even heard a chirp or howl when cornering very sharp with stock suspension. ABS Always works perfect with them, never ever slid even when I romp the brake pedal to test them out. Lightly modded VE-auto can barely brake them lose taking off.
Cons:
I suppose some people might think rough ride quality would be a bad thing so I guess I should put that in here, but I tend to like the "riding on a skateboard" feel going over bumps and things. They're by no means that comfortable of a tire, but they are surprisingly quiet for how the ride is... But if you want a performance summer tire, you're apparently going to lose some ride quality; but I'm sure you know that.
Old Mar 6, 2008 | 09:47 AM
maxitech's Avatar
Pro's:
Cons:
Not even close to my size.
Old Mar 7, 2008 | 10:30 AM
Pearl93VE's Avatar
I can has?
What do you mean? You can get them in almost any size?...
Old Mar 7, 2008 | 11:48 AM
Greeny's Avatar
¯\(°_o)/¯
They are only available in 16" or 18"
http://www.tirerack.com/tires/Sizes....+Pole+Position
Old Mar 8, 2008 | 12:32 AM
Pearl93VE's Avatar
I can has?
... That is strange, I don't have either of those sizes... and I've seen people with 17's have them.
Old Mar 8, 2008 | 01:14 AM
Greeny's Avatar
¯\(°_o)/¯
Might just be a tirerack thing
I do believe this particular tire is no longer produced (closeout), so that might explain the now limited size choices.
Old Mar 8, 2008 | 01:19 PM
MorpheusZero's Avatar
S03s were designed with wet traction as a primary concern. S02s were designed more for dry pavement IIRC.
But they are both great tires if you can swing the coin
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
