windows dont roll up or down?
Old Feb 9, 2008 | 09:23 PM
tallkid2201's Avatar
ok so i blew my 120a fuse the other day. replaced it. everything works again except the windows. the locks work from the main window switch but the windows dont. the motors are fine because i checked it with a seperate battery. also if it helps....when the door is open and the car is off but the key turned all the way it keeps beeping? it should beep only 5 times and then stop. the light on the drivers door also wont turn on but the bulb might be blown. last, when i lock/unlock, the lights dont flash anymore. only the fronts when i lock
any ideas on this one?
Old Feb 9, 2008 | 10:59 PM
pmohr's Avatar
No more Maximas...
BCM controls most of those functions, have you checked all other fuses?
Old Feb 9, 2008 | 11:25 PM
kaneda_77's Avatar
exactly... check those fuses
Old Feb 10, 2008 | 07:58 PM
kaneda_77's Avatar
I checked, and it is NOT a 120 amp fuse that is supposed to go there. I put one in my max to test what would happen instead of a 140 amp and the windows, power locks and wipers wouldn't work. Just thought I would let you know.
Old Feb 10, 2008 | 08:19 PM
Mr Willis's Avatar
This may sound stupid but make sure your window lock button isn't pushed in. That buttoned PWNED me one time.
Old Feb 10, 2008 | 08:41 PM
haha no i thought about that one already. havnt had time to check on fuses yet cause of work and school. but hopefully if its not the fuses i can run over to nissan tuesday. keep the ideas comin though, i hate goin to the dealership....THEY TAKE MY MONEY!
Old Feb 10, 2008 | 09:04 PM
kaneda_77's Avatar
That would be funny if it was.
Old Feb 10, 2008 | 09:29 PM
Mr Willis's Avatar
lol,yeah it would be. That thing caused me to take off my door panel, boy did i feel like an idiot.
Old Feb 11, 2008 | 06:14 PM
thats weird becuase my max always had a 120 a fuse and everything worked fine before that??
Old Feb 11, 2008 | 08:35 PM
kaneda_77's Avatar
for all i know, the 120a fuse was over spec'd to 140a... who knows. point is, if you look on that top box where it tells you what fuses are and what the amp value is, you will see that it is a 140a.
Old Feb 12, 2008 | 02:21 PM
i will most likely go to napa and get teh 140a fuse but....
i checked the fuses and they are all good. i have an idea that it is the main wiring harness from fuse box to door?
also i found that the windows roll down when i hold the unlock button still. problem is ....they dont go up. is therer way to get the remote to roll them back up with a certain mod?
any thoughts on these ideas??
Old Feb 12, 2008 | 05:23 PM
kaneda_77's Avatar
trust me.... before you get into wiring that stuff, put the 140a in there.
lol... nope... you can't roll them back up unless you run 12v current through the window regulator directly.
Old Feb 12, 2008 | 05:26 PM
ya trust me ive gotten out the spare battery for the windows a few times now by messing up. ill look into the fuse tomorrow. it would be cool to have that as a a mod though
Old Feb 14, 2008 | 08:27 PM
STILL NOT WORKING.......dealershipwants 200......no way
Old Feb 14, 2008 | 08:45 PM
kaneda_77's Avatar
so you put in a new 140a fuse?
Old Feb 15, 2008 | 11:50 AM
*PROBLEM SOLVED*
it turned out ot be a 7.5 fuse called "ELEC PARTS"......i really wasnt expecting that.
Old Oct 25, 2008 | 03:46 PM
AcuraLegend's Avatar
Im having similar probs. Where was this 7.5 fuse? Under the hood or at the kick panel?
Old Oct 25, 2008 | 05:03 PM
max ride 41's Avatar
doh.......
Old Oct 28, 2008 | 11:02 PM
the fuse is in the dash panel next to the steering wheel
Old Oct 29, 2008 | 09:41 AM
Nissantrix's Avatar
man, i'd totaly feel like an *** if i did all that work for the button to be down! lol
Old Aug 4, 2011 | 03:16 PM
brutus_skx's Avatar
Wow, this one is TOO funny. lol I just got owned by mine for the last 72 hours! HAHAHA!!! I was pulling the temp gauge in my dash and my little helper (daughter) was in the car watching and handing me tools. I also pulled out old wire harnesses no longer in use that were put in by previous owners. When all was said and done all my passenger windows didnt work and were stuck open except for my driver side operated just fine. I spent the last 72 hours re looking wires that I messed with, fuses and everything I had messed with. I even put the dang temp gauge back in thinking maybe i needed to complete some circuit. I had been driving the wifes truck around and leaving the max in the garage due to rain.
I searched this forum and came across your post, ran out to my car and hit the button...BAM!!! all my windows worked. lol Oh I felt a idiot and my wife laughed her head off at me. LOL!!
Old Aug 5, 2011 | 07:55 AM
bobflood's Avatar
Don't feel like the Lone Ranger! I had the remote trunk release in one of may cars suddenly stop working. After many hours of troubleshooting, checking, chasing electrical circuits, swearing, etc - I found that I had accidently hit the "valet" override button in the glove box that disables the trunk release.
Old Aug 5, 2011 | 10:06 AM
cashoit's Avatar
Fbana41
Aug 29, 2016 12:18 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
