tire size
Old Feb 12, 2008 | 02:15 PM
03maxima1's Avatar
tire size
Whats the recomended size tires for:
19x8.5 front
19x9.5 rear
is 235x35 and 245x35 good?
Old Feb 12, 2008 | 05:35 PM
Fast1one's Avatar
19x8.5 front
19x9.5 rear
Offset and generation would be nice, but aside from that...
I would do 245/35 front, 255/35 rear...245/265 would be better, but it may rub
Old Feb 13, 2008 | 09:21 AM
03maxima1's Avatar
sorry bout that. 2003 max - 40 offset
Old Feb 13, 2008 | 10:07 AM
Fast1one's Avatar
I would still say 245 front/ 255 rear then since 4th/5th gens have the rear beam...if you want to have the same sidewall look (slightly stretched like the rear) then 235 front, 255 rear....may have to roll the rear fender...
If your ambitious you can try 245/265, but I don't know if a roll will be enough to clear the fender (most likely you should be fine). How much are you lowered?
Old Feb 15, 2008 | 10:06 AM
03maxima1's Avatar
h-techs so 1.6 rear and 1.0 front
Wheels are 19x8.5 front and 19x9.5 rear
I think 235 and 245 would look good I dont want to make any modifications to fender.
Old Feb 15, 2008 | 01:39 PM
LeX's Avatar
LeX
Nissan by Nature
On my max I run 38 offset and 8.5 front 9.5 rear (2002 maxima) and I run 245 and 265... only time ever rubs is on HUGE dips on the back on one side due to rear beam centering issue (dropped quite low on coilovers)
Old Feb 15, 2008 | 06:07 PM
NmexMAX's Avatar
dot dot dot ...
I rub on one side only on 245 on 8.5's +18mm
Old Feb 15, 2008 | 06:32 PM
IHAVEA2KMAXIMA's Avatar
225/245
Old Feb 15, 2008 | 08:32 PM
Fast1one's Avatar
Gah, i forgot about your setup! There you go, 245/265...
Old Feb 15, 2008 | 08:55 PM
MrDicks95SE's Avatar
Offset Is Everything.
high offset FTL.
Old Feb 16, 2008 | 07:55 AM
LeX's Avatar
LeX
Nissan by Nature
Originally Posted by Mr****s95SE
high offset FTL.
you have high offset wheels, just with spacers
Old Feb 16, 2008 | 10:35 AM
not with my next set of wheels...
Old Feb 16, 2008 | 03:41 PM
Fast1one's Avatar
"Anything you can do, I can do better" Just wait till i win the lottery
Old Feb 17, 2008 | 11:19 AM
LeX's Avatar
LeX
Nissan by Nature
i'm lookin forward to it. Def post pics asap
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
