no A/C!
Old Feb 22, 2008 | 12:54 PM
nismax1994's Avatar
no A/C!
The light on the A/C button comes on but the compressor does nothing. I know a little about AC, I think if it was just low on r134 it would kick on and then kick off right? It does nothing.
Old Feb 22, 2008 | 12:57 PM
mikekantor's Avatar
Pull the plug out of your condenser and close the plug's circuit with a paperclip while the button is pressed, the fan speed is 1-4, and the car is running. Do you hear the compressor click and start working?
Old Feb 22, 2008 | 09:44 PM
ColombianMax's Avatar
Your compressor/clutch will not engage unless there's enough refrigerant/pressure. I believe the clutch engages even when the heater is on but for the windshield defroster only. You can try jumping it for a second to see if it turns on but if it doesnt while jumping it directly to the batt then you might need a compressor.
If you decide to test it by jumping it and it does work, do not leave it connected just to get around the issue, I do believe that will harm the compressor in the long run.
I wish I was in need of AC right now! We're in the low 20s and teens
Old Feb 23, 2008 | 10:13 AM
nismax1994's Avatar
I think I have destroyed my AC system.
I jumped the compressor to the battery it came on, but low side pressure was 0. I let some r134a in and it all blew out of the low side hose.
A couple of years ago I took the hose out of its bracket so that the strut tower brace would go over it. Apparently its been doing a bit of rubbing on the pulley although it appears to have sufficient clearance at idle, a hole has appeared.
I'm trying not to get too angry with myself here, but my stupid mistake has caused this. I don't know what to do, I assume the system is contaminated and I can't just replace the hose and recharge.
Old Feb 23, 2008 | 05:35 PM
internetautomar's Avatar
mod or sell?
a hole that small is unlikely to have contaminated your system.
replace the hose and drier, recharge the system, check for leaks and hopefully drive happy.
Old Feb 23, 2008 | 06:57 PM
DanNY's Avatar
Ad·min·is·tra·tor
i agree...
replace hose, use new o rings, replace dryer, vacume system and check for leaks...recharge R134a and oil.
Old Feb 24, 2008 | 12:59 AM
Wiking's Avatar
Originally Posted by nismax1994
... I know a little about AC, ...
Me know even less. That is why I did some fact finding... hope this hlps:
http://www.cardomain.com/ride/748507/7
Old Feb 24, 2008 | 09:31 AM
nismax1994's Avatar
I can't find a hose on any site, is that only from the dealer?
And thanks Wiking, for the link, good site!
Old Feb 24, 2008 | 11:56 AM
Wiking's Avatar
I can't find a hose on any site...!
If u go to dealer, your car value will triple (=positive thinking)...
Cut it, insert suitable/tight metal pipe in/between, clamp it. Two clamps, 2$...
...Or find specialty shop sellin industrial rubber bits, hoses. Take your whole problem out, visit the shop with it and they will re-build it to you. 50$ ?
Old Feb 24, 2008 | 03:25 PM
mod or sell?
keep going.
the hose is like $125 at the dealer and most places around me charge at least $75 to redo the hose.
Old Feb 24, 2008 | 05:40 PM
keep going.
Brian cool heat (my old job) did my hoses for 35 bucks each...wonder if they still charge that much with that ***** of a new owner they got now.
Old Feb 24, 2008 | 05:42 PM
mod or sell?
But you were an employee, no?
Old Feb 24, 2008 | 05:59 PM
Not at that time...I just decided to ask if they were hiring when I picked up the finished hoses and got hired the next day.
Anyone can go there and get it for $35 depending on the car, for our maximas should be $35 bucks...its the length of the hose that brings the price up
Old Feb 24, 2008 | 08:37 PM
DanNY's Avatar
Ad·min·is·tra·tor
with AC i highly recommend you DO NOT use regular hose clamps.
Old Feb 25, 2008 | 06:58 AM
mod or sell?
when they make new ones, they crimp new ends on.
even if it is a low pressure line, there are still special A/C hose clamps to use.
Old May 21, 2008 | 12:30 PM
walterh's Avatar
does anyone know where the low pressurre side inlet is? I can't find it??
Old May 21, 2008 | 12:32 PM
walterh's Avatar
I guess I should be more specific. Does anyone have a diagram of where the low pressure side inlet for adding freon to? I've been looking and I can't find it. Please help!!!!
Old May 21, 2008 | 02:54 PM
Cinnamint's Avatar
Random thought, our cars don't use r143a....do they?
Old May 21, 2008 | 03:12 PM
walterh's Avatar
no, they don't. you have to covert them to 134a or pay a fortune for R-12.
Old May 21, 2008 | 04:46 PM
92gxe/cg2's Avatar
93 and newer is R-134a, 92 and older is R-12.
Old May 21, 2008 | 06:49 PM
mod or sell?
Depends on the year.
even if it is R12 I recommend converting it to 134a because of cost and future availability.
I actually have 2 14oz cans of R12 and 1 30lb of R12 for sale if anyone is interested (continental USA only).
Old May 21, 2008 | 06:50 PM
mod or sell?
Look for a blue cap if you have 134a already
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
