How to get the ball joint out of the hub?
whack the side of the knuckle where the ball joint runs through it while you're pressing down on the control arm. use a decent sized hammer- 1-2lb is good. not some dinky little 8oz POS. hitting it there will cause the metal to momentarily distort and the ball joint will pop loose after a few hits.
DONOT use a pickle fork, you will destroy the rubber boot on the BJ. I like the hammer method and it has worked for many yrs consistently. Take the cotter pin off, remove the nut on top of the BJ, and then whack it on the steering knuckle meets the LBJ. It will pop out in no time..
Last edited by Love_00_Max; Mar 7, 2008 at 08:10 PM. Reason: Edited to add removing the BJ nut
Yeah, I need a "dependable" daily driver because my Starion isn't hacking it! lol But the Maxima needs some TLC as well. The bushing in the LCA is shot, I need a new timing chain tensioner, tires, starter (lifetime warranty but I need to replace it), O2 sensor and clean out the EGR system. There's probably more but that's my list so far!
So, is there a snap ring on the ball joint or not? I have heard of one being there but only to hold it to the LCA, not the spindle/hub. You typically just bang the LCA and/or hub and it pops free.
I went and got a real hammer and a pickle fork (I'm replace the whole LCA that has a new ball joint in it so I don't care about the old ball joint). I'll try the hammer first so I can try to keep the old ball joint as a spare.
I thought that huge bolt holding the LCA to the body would be my problem spot but that way easy! lol
Good luck with the repairs. Hope to see you around soon.
litch
123
Jan 4, 2024 07:01 PM
Andy29
Sep 29, 2015 05:32 AM
