Smoke and no temperature reading
So it's done...sort of.
I replaced my valve cover gaskets, spark plugs, spark plug wires, distributor, rotor, fuel filter, a few hoses and cleaned the tb. I'm too old for this ****!
Anyway, car started up good and idles smooth. There were a couple hoses that I hadn't put on tightly enough so I fixed that and the hissing went away.
The problem I'm having is the engine starts to smoke. It's in the front and seems to be coming from underneath the vc. Also, the temp gauge stays on cold. Doesn't even move. I've got some fluid leaking. It's not oil, seems to be coolant. Although when I look at it, it's almost yellow.
Anyway, if anybody's got any ideas I would really appreciate it. If I can't figure this out my DIY project is going to end up at a mechanic's.
Probably just some residual oil/gunk on the engine after your gasket job, just drive it around for a while, this will help burn it off quicker..
As for the temp gauge, you either left your chts(coolant head temp sensor) unplugged, or the wire/sensor is broken.
I will find a pic of the sensor brb..
http://s164.photobucket.com/albums/u...t=MVI_2251.flv
mine had this problem
If you just cleaned your TB the smoke is most likely all that crap from cleaning it burning off. Im guessing you left TB on and sprayed and wiped clean with rag?
where exactly is the fluid leaking, and does it match the color thats in your radiator(wait until cold to check)?
.I actually took the tb off and cleaned it. Cleaned the intake manifolds too.
I actually did leave one of the coolant hoses that attaches to the rear of the upper manifold off so it was shooting coolant the first time I started up.
Smoke is whitish(??) and the smell is...well, not oil. I think coolant is a good bet. I checked the hoses but ran out of daylight. I will look closer tomorrow morning.
you get the temp gauge working yet?
if you for whatever reason dislike the bleeder valve tho, or if you have the bleeder valve bypassed, then the alternate method is to jack the front end of the car up as high as you safely can, uncapping, letting air work up to the top and warm the car up until the coolant rises into the cap, and then maybe try it again later.
Actually wiking, the nice hot air pockets will give a temp needle reading, mostly incorrect(overheating when not really overheating)
Yes, bubble pockets is one issue and may be so. Sometimes hasty fillup will end in missing one quarter of coolant, as bubble causes radiator overflow - before whole system is full.
In such case = IF coolant level is below the sensor --> THEN no cool ant temp reading..
= IF no coolant, THEN no cool ant temp reading..
Or 2. A sensor that will give you a false cold reading=driver keeps driving thinking he has a bad t-stat, or thinks nothing at all= BOOM! 5 miles down the road?
Which kind of sensor would you as a designer want to put in your car?
And re: the fluid leak. I found another point where there is no hose attached. I have looked around but can't see a hose to put there. Looks like it runs up from the transmission and then does an upside down U. Here's a pic:
I hope not to experience youre right with VG...
I also looks like your sensor is in poor condition, you might want to replace it, they are pretty cheap (around $25).
[img]http://pages.sbcglobal.net/johnsons/pics/attach.jpg[img]
Is the male end what capedcadaver is touching in his vid? Yes, the sensor that is attached to that is toast. Do you just pull it off that male end? I tried to pull it a little bit with pliers and it just cracked. It's brittle as hell.
I'm confused about the wire. The wire that broke off the sensor part actually runs together w/ other wires that are taped together. It is just sticking out of this taped bundle and I'm not really sure where it leads. Will I need to untape all that, figure out where it leads and then replace the whole wire. Is your picture a VG or VE? It doesn't look like mine.
All you need to do is strip some of the wire away from the end where it broke off the plug, add a connector like in the pic. attach it to the male end of your new chts.
Think about that for a minute, if you experience coolant loss from a busted hose/whatever=all/most your coolant is gone. Then how would a car company want to design their temp needle sensor? Would they want it to 1. detect a no coolant condition= the temp gauge goes weeewoopeee! all the way to H in a hurry to warn the driver that he is going to blow the engine up if he/she doesn't shut it down now!?
I wasn't saying my way was the correct way. I was asking. I know a lot of vehicles may be overheating when low on coolant but the gauge won't indicate so. Glad to know ours is kind of a "fail safe" then.
One issue is if failure comes via boiling, most cars a like u say. Another issue is if u start half empty...
The V6 coolant flow is relatively complicated, spent some time studying, check
http://www.cardomain.com/ride/748507/8
The fluid is oil. It is coming from the front cover where I didn't make sure the new gasket was seated properly. It is bulging out and I'm sure that's the spot where the oil is escaping. I've loosened all the screws I can but it's tough moving that gasket. I'll let it cool down so I can get in there with my fingers instead of a screwdriver.
doctorpullit
Oct 28, 2019 10:58 PM
mkaresh
Mar 12, 2018 06:48 PM
