Weird engine noise at speed
Old Mar 25, 2008 | 07:19 PM
BenStoked's Avatar
Jesus was a Zombie.
Okay, on my 91 se, I have a strange sound(like a buzzing) in my car. On a nice day, I get into my car and can drive hard (any gear)with no sounds. However, when the engine warms up a little, I get the noise from my car. In first gear, I can rev all the way up to 6k at full throttle with no problems. however in 2nd at full throttle, at about 4-4.5k the engine starts to buzz. if I let off the clutch, the rpms drop and the noise stops. If I ease off the gas(clutch engaged), the sound persists, but is much quieter. In 3rdand 4th it's the same deal, but at about 3.8-4.2k. I haven't gotten it to do it in 5th(I dont drive that fast, usually 3300 tops.) and it also does not do it in neutral. I do not know if its related, but I have a couple of exhaust studs broken, and need to replace the input shaft bearing (short on money, atm...)
What I need to know is what would cause this weird noise. It isnt the normal exhaust "tick," and the engine runs great, asside from this. It does not sound like a rattling exhaust, either. Its more... rough? almost strained. but the intake and the exhaust sound okay. the car feels good too.
also, if anyone can offer suggestions on how to diagnose it, please let me know.
Old Mar 25, 2008 | 07:23 PM
Greeny's Avatar
¯\(°_o)/¯
your car is broken
Old Mar 25, 2008 | 07:27 PM
mikekantor's Avatar
So is it tied to engine speed exclusively, or is it more related to vehicle speed?
Old Mar 25, 2008 | 07:29 PM
Greeny's Avatar
¯\(°_o)/¯
Broken motor mount/s maybe?
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by Greeny
your car is broken
I figured that...
engine speed, but only at speed, and not in 1st gear.
Old Mar 25, 2008 | 07:35 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by benstoked
I figured that...
bad 1st gear synchro or bearing? when 1st engaged nothing is happening but when 1st is freewheeling in another gear it's making noise?
Old Mar 25, 2008 | 07:39 PM
mikekantor's Avatar
My best guess is that one more or several more exhaust studs have broken off, so the sound changed.
Old Mar 25, 2008 | 07:50 PM
BenStoked's Avatar
Jesus was a Zombie.
do you guys have any suggestions on how to diagnos if that may be it?(I do need mounts, but like i said money is tight...) I am more concerned about whether this is or can be fatal to the engine/tranny than just fixing a weird sound. when i have some cash available, i can start working on the other important stuff.
Old Mar 25, 2008 | 09:58 PM
KRRZ350's Avatar
Well considering an exhaust rattle, or trannsmission related could be the cause, you should probably wait until you R&R the trans and exhaust before worrying about a sound that is more than likely a side effect of the major issues you have going on.
Old Mar 25, 2008 | 11:47 PM
GAMERA30's Avatar
From: Long Beach, CA is where i live. Queens NYC is always home.
I recommend u fix the enhaust studs to help isolate the noise. Use 300zx turbo studs.I heard they are stronger
Old Mar 26, 2008 | 04:58 AM
Wiking's Avatar
... how to diagnos if that may be it...
Give us your noise, so we may diagnoise...
U say warming is one factor.
Q: do your engine mounts warm up?
Q2: What parts do warm up which may have affect?
U say rpm is one factor.
Q. What does change as rpm changes?
Part answers: Air/Exhaust Flow = leaks. Engine Angle = ?. Accessories, Belts...
Solution no.1 ... Start driving like granma, max 2200rpm.
Old Mar 26, 2008 | 05:23 AM
BenStoked's Avatar
Jesus was a Zombie.
except when i get on the hi-way, i do. ****ing bastards wanna get on at 35-40 mph, while the truckers are doing 70.... i dont wanna die...
Old Mar 26, 2008 | 06:13 AM
Wiking's Avatar
Things will become pretty tough before one does want to die... My survival-solution is the 6.5 redline, seeking info how to change it to 7k.
Q: are there no weird sound while stationary, playing with rpm's? If not, the causes are (?) limited to engine angle -effects, horse pwr transmission -route onto asphalt
Hoses etc rubber parts characteristics do change when they become hot.
Old Mar 26, 2008 | 12:01 PM
cwm9's Avatar
Audio recording?
Old Mar 26, 2008 | 12:06 PM
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by cwm9
Audio recording?
better!
video 1 (sound 13 seconds in, time mark 00:12)
Video 2 (sound at 4.5 seconds in, time mark 00:05)
Old Mar 26, 2008 | 01:12 PM
Wiking's Avatar
better!
video 1 (sound 13 seconds in, time mark 00:12)...
I'd put the fault on some accessory bearing. Take accessory belts out one after another and repeat the test. Waterpump belt should not be out too long...
On the other hand, if that was true, the same sound should be manifested stationary. Hmm.
Old Mar 26, 2008 | 01:24 PM
BenStoked's Avatar
Jesus was a Zombie.
those both were my thoughts... go ahead and try anyway?
Old Mar 26, 2008 | 01:41 PM
mikekantor's Avatar
The audio wasnt extremely clear, but to me it sounded the same as when the starter pinion pushes out and grinds against the flywheel.
Old Mar 26, 2008 | 01:59 PM
BenStoked's Avatar
Jesus was a Zombie.
like when you try to start the engine when it running? no i dont think it sounds like that.
the video was about the best i could do with what i have, and aside from the volume of the noise(just a little louder), it sounds about like it does when im driving, at least on my computer speakers.
Old Mar 26, 2008 | 05:15 PM
tuck your camera under the cables on top of the tranny and hook the armstrap into the N/R switch harness. then drive with your camera recording while it's under the hood.
and ya i'm serious about that. i did it once and the results are a lot clearer.
Old Mar 26, 2008 | 05:50 PM
BenStoked's Avatar
Jesus was a Zombie.
its not my camera... but i'll see what i can do tomorrow.
Old Mar 27, 2008 | 01:32 AM
Wiking's Avatar
Yes but as the last resort. Easiest tests first. (What are they?)
If it was my car, I would loose sleep until the source was found... (I love company leasing cars as daily drive - sigh. nowhere in sight)
Anyways, like a bearing failure, intermittently resonating...
If you keep pedal steady, will the sound be the same? Or is it limited only into acceleration? How does it respond to accel/decel -'pumping'?
Old Mar 27, 2008 | 05:51 AM
BenStoked's Avatar
Jesus was a Zombie.
it gets quieter or stops all together sometimes, if i"accel/decel='pump'", wiking.
Old Mar 27, 2008 | 06:23 AM
Wiking's Avatar
That is consistent with a worn bearing under varying load. But howTo locate it...
Can you get external microphone (5$ at radioshack), clamp it on tranny etc so that engine noises will be transmitted mechanically directly into it. Then changing mic positions, seeking the source...
Old Mar 27, 2008 | 06:36 AM
BenStoked's Avatar
Jesus was a Zombie.
if its a bearing, i wonder if a stethascope would reveal this at idle....
brb
edit:
damn, i don't know where my dad's is at, and a screw driver wasnt long enough for water pump and ps pump.
ill swing by autozone later and see if they have one...
Old Mar 29, 2008 | 01:36 AM
Wiking's Avatar
if its a bearing,....
Check out that exhaust, heat shields cannot resonate and/or touch chassis.
Old Apr 3, 2008 | 12:23 PM
BenStoked's Avatar
Jesus was a Zombie.
okay, its been a few days, and i have done some looking at the engine. first, as wiking sugested, and asside from a few busted manifold bolts, everything seems okay.
next, i checked the belt tension on my wp/ps belt, and it seemed a little tight. i loosened it a little, and now i can get the "noise" w/out load. Video here:
it seems to be coming out of the intake (), which is weird, because there seemed to be a direct link to my loosening of the belt, and the change(is that the right word?) in the sound.(I could be wrong about this, but im pretty sure.and the entire engine is loud at wot...)
Old Apr 3, 2008 | 05:01 PM
what's with the smoke?
Old Apr 3, 2008 | 05:37 PM
BenStoked's Avatar
Jesus was a Zombie.
broken exhaust studs, ftl. gonna try to fix that this weekend.
Old Apr 3, 2008 | 08:39 PM
Alex_V
Id take off the belts completely just to test out the sound. IE warm the engine up, take off the belts, start and test and then put them back on and test again.
There isn't any power loss is there? Oh and the VG has those butterflys in the intake, I wonder if they are causing something weird. Maybe take off the vac fitting for it and see if that was causing any thing.
I really couldn't think of what it could be to change the intake note so much. I would think its a bad injector failing but its semi predictable so IDK. Id vote for fix the known issues asap and trouble shoot after.
~Alex
Old Apr 3, 2008 | 09:03 PM
BenStoked's Avatar
Jesus was a Zombie.
no, there is no noticeable power loss.
as a side note, the tube between the headlight and filter box had been removed, allowing for a little better sound and a little oomph(butt dyno says "slight power gain") but that is not the cause of the sound, it probably makes it more noticeable
Old Apr 4, 2008 | 01:07 AM
Wiking's Avatar
... a direct link to my loosening of the belt, ...
Waterpump bearing? Disconnecting the belt will take that possibility out. For the pump, the sound is rather harsh ... if its not the pump, then valve or piston ring problem?
captchaos
Mar 15, 2016 12:18 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Max139617
Sep 6, 2015 06:02 PM
jfl330
Sep 4, 2015 01:44 PM
pktaske
Sep 4, 2015 08:40 AM
