Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rotor Compatibility?
Old Mar 25, 2008 | 07:27 PM
NewfoundlandDud's Avatar
Hey this might be a long-shot, but a local shop is clearing a set of Brembo XD/Slotted Rotors for an 05-08 Tacoma.
I am wondering where I can look-up the dimensions for these to compare them to the 13" Cobra Rotors for a BBK?
I think that the Bolt pattern is 5x114.3 if that helps any.
Here's the Link:
http://www.nlclassifieds.com/classif...essories/66058
Old Mar 25, 2008 | 07:44 PM
redls1's Avatar
MAXIN' ON
From what I looked up its only a 12.5" rotor.
Old May 12, 2008 | 02:15 PM
GAMERA30's Avatar
From: Long Beach, CA is where i live. Queens NYC is always home.
even tho the rotor had the same bolt pattern, the offset of the rotor can make your brake swap sour. Example: 13" Cobra rotor and 6th gen rotors. Cobra rotor has the same bolt pattern as a Nissan, but the holes are larger and the offset makes the rotor move outward. 6th gen rotors are more inboard.
I tried to mount a Z32 caliper w/ Jeff brackets on my 3rd. gen and it didnt clear the rims. ( Had to use Infiniti J30 calipers) I have a friend who also has a 6th gen. We mounted my rims on his car and there was no clearance issues. We even mocked up the Z32 caliper and it cleared also. A look at the cobra rotor showed that it had a different offset compared to a Nissan Rotor.
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
Lowered_a33
Sep 1, 2015 07:49 PM
