Where did you install your catch can?
OK.... for everyone who installed a catch can
where did you install it???
yes i know i have an altima...
first of all, YES I KNOW my engine bay is dirty...
i say that for all the annoying people like me who will say
you need to clean your engine bay
i am just trying to get an ideas for later when i change out the battery ...
you need to clean your engine bay i am just trying to get an ideas for later when i change out the battery ...
i mounted mine on the power steering line but its not much of a can its the ghetto little compressor air filters you get from home depot. It worked at first but stopped catching oil after an ounce or two.
how does that one work for you? whered you get it? price?
First, get rid of that ebay catch can. All I have heard were bad reviews about those.
Go to Home Depot or Sears and buy an "air/water seperator" that they sell for compressors. Alot smaller too so you'll find a nice spot to mount it.
-matt
BTW: Is that an Altima engine bay ?? Pretty dirty man lol..
-matt
-matt
-matt
and yes.. altima.. and yes dirty....
i dont think that i would of have installed it on the batt bod like that. got a feelin that its gonna rub through with those batt vibrations and youll be leeking sone nasty hazdrous acidic stuff.
that is all...
not sure muffy's catch can would be any good anymore.....
i want a red top when i need a replacement!
Reduce blow-by, which is known to cause gasoline's octane level to drop (add oil to gasoline = lower octane rating), which, in affect, sometimes, causes pinging.
Also keeps the IM a little bit cleaner (less oil / blow by).
-matt
-matt
Thats a good idea and its prolly alot more effecient than a catch can
I have the home Depot set-up, and well, it acts a s a catch can, since you have to remove the filter (air / water separator). If not removed, it will not work as a catch can and cause bad symptoms such as those associated w/ a bad PCV valve since the air water / separator replicates a clogged PCV valve.
How do you figure?
Mar 12, 2020 12:06 AM
bbsitum
Sep 11, 2015 04:55 PM
i would expected something more witty than that.... tisk tisk....
